old4570
Ok .. $30 USD off Flea-Bay , came with one 18650 Batt and a belt holster .
Now I did order a 3-8.4volt R2 version , but I got the 3.7-4.2Volt one instead . Ive been waiting 2 weeks for the correct pill , but I dont see it happening , so no plug for the seller :mecry:
I have 2 Batts to test with, Trustfire 18650 - 2500mA , and Ultrafire 18650 2400mA Protected . I also have 2 different light boxes , so bear with me , also all light box readings will be minimum . One thing I did notice on high was that the R2 fades a little when it starts running warm , and it does run warm .
More latter :
Trustfire 2500mA :
Hi - 1A - 210Lux LB1 - 12000Lux LB2 - Throw 7500 - 7000Lux @ 1 meter
Med - o.66mA - 130Lux LB1 - 6400Lux LB2 - Throw 4700Lux
Lo - o.33mA - 70Lux LB1 - 2900Lux LB2 - Throw 2200Lux
Ultrafire 2400mA Protected :
Hi - 1.12A - 210Lux LB1 - 12000Lux LB2 - Throw 7800 - 7000Lux @ 1 meter
Med - o.72mA - 140Lux LB1 - 6400 LB2 - Throw 5500Lux
Lo - o.36mA - 70Lux LB1 - 2900Lux LB2 - Throw 2800Lux
Now as can be seen from the results , on Hi , as the temp rises output drops to around 7000Lux Throw , the temp seems stable at this point as does output , better heatsinking might be in order .
I have no build quality issues , this is an excellent product , everything is spot on , I might try the aluminum foil thing where you wrap the pill for better heatsinking .. Other than that , I can highly recommend the Solarforce L2 , and so far the only issues are that med and Lo might be a little on the too high side for output , but with a good 18650 this may not be a real issue , for the CR123A lovers , maybe not so good .
I hope to buy a pair of Ultrafire 3000mA 18650 batts in the future , to run this flashlight on , and in Lo , one would hope for 8Hours or better ...
Just check out that current draw on Hi - Wow ... 1 - 1.1A
CREE R2 (114-120 Lumens @ 350ma) , one could almost believe the 300Lumen claim from Solarforce .. :thinking:
