Does anyone know if the Solarforce XPG drop in comes in a 3 mode(high,med.,low) Version? I know they have a 5 mode but don't care for the strobes. Thanks
Yes it does. Information taken from the Solarforce website:
Easy to operate ~ Runtime KING BULB, Maximum Runtime 30 HOURS, more than a DAY!!!!
The flashlight bulb function may able to safe your life and make you survive during emergency situation
3 mode R5 XP-G Cree led bulb
- Provide 320 Lumens Max output
- Reflector aluminum reflector (Smooth reflector)
- Solarforce R&D driver circuit to protect Li-ion battery from over-discharging
- No. of mode available : 3 Mode
100% 40% 10%
Very user friend, just click on/off once to change mode
With Memory IC (turn off for 3 second will memorize the last mode, When you turn on again, it will be on that memorized mode)
- Working Voltage : 0.8V to 4.2v, under the circuit
- Battery configuration :
18650 3.7v x 1pc
CR123A 3.0v or 3.7v x 1 pc
- Runtime :
18650 3.7v
~ 100% brightness – 3.5 hours
~ 40% brightness – 10 hours
~ 10% brightness – 35 hours
CR123A 3.0v or 3.7v
~ 100% brightness – 1.5 hours
~ 40% brightness – 4 hours
~ 10% brightness – 15 hours
- Compatible for : Solarforce L2 L2M L2x L2P L2i L2r (fit for all L2 Series)
