Sold/Expired SOLD: One more ---- Mag 2C * XPG R5 * 1.6 Amp *Hybrid Reflector*Over 500 Lumens*
ma_sha1
CT, USA
All sold
Cree recently raised XPG max current rating to 1.5 Amp, stated spec up to 493 lumens @ 1.5A:
http://74.125.93.132/search?q=cache:...&ct=clnk&gl=us
This light is designed to push XPG-R5 to its maximum spec potential:
The light uses 2 Li-ion with 2x800mA constant current driver wired in parallel to deliver 1.6 Amp total current to LED. I learned to use this driver from the original DEFT thread here (See post #1 for the driver):
http://www.candlepowerforums.com/vb/...d.php?t=183261
This will push the XPG R5 over 500 LED lumens.
A new reflector that I am proud to introduce with this light: Hybrid Sputter Reflector:
  • It's known CPF knowledge that OP reflector gives much better beam than SMO
  • It's known CPF knowledge that SMO can out throw OP by 30%
  • It's known CPF knowledge that the lower half of the reflector is mostly responsible for poor beam quality of SMO.
  • Hybrid reflector (More OP on bottom half) has been introduced as a product by FM in the past, however, the top half is still OP not SMO: http://www.candlepowerforums.com/vb/showthread.php?t=207494
The Special Hybrid Sputter Reflector introduced with this light for the first time, Light OP treatment only on the bottom half, the Top half remains SMO. As a result, this light is able to achieve perfect beam without loss of throw vs. SMO. Finally, a perfect harmony between perfect beam & ultimate throw is reached.
Spec:
  • Brand New Mag 2C in Titanium Grey/Gun Metal color
  • Powered by 2x Li-ion.
  • XPG R5 on 14mm board (Pure white tint, no green, no yellow)
  • Brass Heat sink
  • 22 AWG Silver Coated Teflon Wires
  • Dual 800mA CC driver delivering 1.6 Amp to the Led.
  • Custom Hybrid Sputter Mag reflector
  • Over 500 led Lumens from a single led per Cree spec
  • Perfect beam, Thanks to the lower half light OP treatment
  • Ultimate throw, thanks to the SMO of top half of the reflector
  • This will blow away the Malkoff XPG drop-in & possibly the Hound dog thrower.
  • This would give you 2-3 hours of long Run time if 2x C-lions are used.
Price is $95,
add $10 for Shipping & PP Fee. USA Only. Batteries not included.
I left the battery tube stock, but there are many many ways to run 2xLi-ion in a Mag 2C, the light will Run on:
  • 2x18500 protected Li-ion with a DIY PVC battery sleeve
  • 2x18500 un protected Li-ion with a DIY battery sleeve
  • 2x17500 protected Li-ion with a DIY battery sleeve
  • 2x17500 un protected Li-ion with a DIY battery sleeve
  • 2x18650 protected Li-ion with download's Mag C Ring Kit
  • 2x18650 IMR 18650 with recessed spring mod
  • 2x18650 unprotected li-ion with recessed spring mod
  • 2x DX 25500 C-lion, unprotected version
  • 2x AW IMR 26500 if bore out the battery tube to 26 mm
  • 2x AW old protected C-lion with a an AW C-lion 10mm cell extender
  • 2x DX 25500 C-lion, protected version with a an AW C-lion 10mm cell extender
  • 2x AW old protected C-lion with a FiveMega deep & Wide SS Mag C tail Cap
  • 2x DX 25500 C-lion, protected version with a FiveMega deep & Wide SS Mag C tail Cap
AW C-lion 10mm cell extender sold here: http://www.lighthound.com/AW-C-Cell-...ght_p_109.html)
FM's Deep & Wide mag C Tail CAP sold here: http://www.candlepowerforums.com/vb/showthread.php?t=215997
Beam Shot for white Wall hunters:
Outdoor beam shots will be up against the 5xCree R2/1200 lumen light on the left,
which is a very good thrower, the 5xCree/SMO module is already an excellent thrower, can out throw p7/MCE & SST-50 on OP Mag reflector.
Control Shot:
5xR2 Cree, 1200 Lumens. Distance to the wall about 55ft.
IS0200, 1" exposure,F3.3
Single XPG-R5, SMO/LOP Hybrid Sputter Reflector: >500 lumens
Re: Mag 2C * XPG R5 * 1.6 Amp *Hybrid Reflector*Over 500 Lumens*
bumpty
Another great build, Ma! Not my kind of light, but someone will snap this up for sure, and enjoy it. By the way, I appreciate your signature. There is something joyful about participating in something just for the fun of it. Sometimes doing something for money/as a service can really hurt that intrinsic pleasure. Good luck with the sale. :)
Thanks!
I only put that note up as I had to repeatedly turn down job requests.
Nothing against people doing mods as a service. For me I simply didn't want to turn a hobby that's a stress relief into a "Job" which creates stress :devil:
Bumpty
Re: Reduced: Mag 2C * XPG R5 * 1.6 Amp *Hybrid Reflector*Over 500 Lumens*
Price Reduced to $89
Ma..how is the heatsink fastened into the tube? I ask because I would want to move the build to another C-Mag.
Donn,
The heat sink is plug-in with Arctic Silver 5 thermo paste, not glued shut. The LEDs are hard wired to the driver/switch assembly. It can be un-pluged but you'll need to cut the wires first. Losen the switch, then push it down to expose the twin drivers mounted above the switch & the wires above. De-solder or cut the wires, transfer all the innerts into a new host & then re-solder the wires in the new light.
If you don't feel comfortable doing it, I am willing to do it for you after payment, send in your host & I'll do it for you.
Since you don't care about this host, I'll keep this Gray 2C & it'll be no extra charge on you.
If you can ship to the UK, I'd take it?
Thanks
I'll ship to UK for $10 extra & will only accept PP gift for international transactions. If that's ok with you, this XPG super thrower is yours.
PM sent.
Great, we have a deal - awaiting pm. Although out of respect to Donn I will pass if he takes it ahead of me. After all, he's been around longer than I have! Paypal ready.
SPF
Thanks, Hammer Train
Donn,
Excellent! I'll pay shortly, and get the new host off to you. Please email your PayPal and snailmail address to
Thanks, Hammer. I appreciate it.
Nice grab Donn, I'll have to keep an eye out if he makes another of these.
Please refund my payment and this one is Donn's.
Donn - You're welcome.
Re: SPF: Mag 2C * XPG R5 * 1.6 Amp *Hybrid Reflector*Over 500 Lumens*
I just got payment from Hammer train, I am going to stay out & let you guys decide who gets this light.
But don't forget, on the corner of B/S/T, there's the Might "Turbo" await,
Tri SST-50, Copper-on-Copper-On-Copper, Over 3000 lumens & with a ton of throw :devil:
It looks like it was decided in post #15. HammerTrain has graciously allowed me to take the light.
Thanks Hammer Train, PP refund sent,
Don't forget, there's still the Mighty "Turbo" await, you know you deserve to have it :)
HammerTrain came through, it's yours.
Thanks Donn, email sent with my PP info & My address.
I have a feeling it's that Orange thing coming...:crackup:
:paypal:
The host will leave tomorrow. It may be that orange thing (which would look good in that car up there!), but I have a few other options as well.
Tell me..If I were to use the build in a longer C-Mag..what's the maximum voltage for the drivers..9V?
