POH
I'm working on attaching a K2 LED to a MCPCB for a new light and did not realize that these are to be done using flow soldering. I have no access to flow solder hdw so I'll take a shot at doing it by hand. Though if anyone has successfully done this I'd like your thoughts.
The MCPCB is small - does anyone see any issue if I first put solder on the contact points on the MCPCB (hand solder that is and not flow). Then place the led in place and while holding it with tweezers solder each of the 4 LED leads down by heating them with the solder iron and pressing down on the previously soldered contact point? I got this idea from looking at how they flow solder them as they place the paste down first.
Or is it better to just place the LED on the MCPCB and solder it in one shot?
As this LED has 4 tabs (2 anode and 2 cathode) does it matter it I end up soldering the 2 anodes together and the 2 cathodes together?
I would use no clean flux on the MCPCB and LED leads and preclean the MCPCB.
