I soldered 2 XP-G's side by side in series config., both are in 10mm round pcb and are so close that the pcb's touch each other. When I soldered them, the smoke from the solder somehow fogged up one of the domes but was shining OK afterwards. Is there a special type of solder to use or a lower heat soldering iron to use ? I presently have a 20w thin tip unit.
