Specs for the POB HID???
davedds
I got a POB HID for a fellow CPFer and the wall slug that was sent has the specs of Input 120V 60HZ 9W / Output DC 6V 0.6A
The spec on the POB Box and the outside of the POB says 13.8V DC 750mA.
What do you have with your POB???
My POB charger has a label that says "INPUT: 120V 60Hz 25W" and "OUTPUT: 13.8VDC 750mA" So it seems that you have the wrong charger for it. At the top of my POB charger's label it says: "HON-KWANG Plug in class 2 transformer"
Thanks anyone know of a source for these 13.8VDC 750mA chargers???
http://www.xantrex.com/productcart/pc/viewPrd.asp?idproduct=141
This is the only 13.8V DC 750 aH charger I could find on the web, but I have no idea about how big the metal end of the cord is that would go into the POB's charging jack, and I don't even know if it is the right kind of charger.
Hopefully someone will know if this would be the right kind of charger.:)
Thanks they are out of stock, and even if the tip is not the right one, I could snip it and get the right one from Rat Shack. But the specs are correct!!
Thanks...
I hope they get it back in stock soon, that is unfortunate it is out of stock.
That sounds like a good back up plan to replace the tip. The one thing that worries me about it is that it might possibly be a fire hazard, so I wouldn't leave it unattended.:)
