I'll be going for a week long Hunting / Biking trip in Borneo. Saw a few threads on hunting lights, but I still can't decide if I should part with my hard earned cash for the SR90.
We will be traveling by 4X4 till the first shelter, unload and the rest will be by foot. Taking into consideration of roots and muddy terrain, I would need something that can handle the elements. For the past few trips, I was using Thrunite's Cat for its throwing abilities, however the run time is not long enough as we will be trekking for 3 to 5 hours.
Should I stick to the Cat and bring along spare cells, and risk fumbling with them in the middle of the jungle? We actually had a boar that nearly got away when the Cat went into pulses, that's when my buddy fired blindly.( Not recommended !!!)
The reason I'm choosing the SR90 over anything else, is the run time in low mode which is equivalent to my Cat in high. The only cons is the weight, size and $$$$.
Is there any other 2000+ lumens LED flashlight that can run for 6 hrs on low and still has a high mode if needed?
Thanks in advance.
Thanks in advance.
