SSC P7 in Mag reflektor
worldedit
I have a Mag 2D for a multi Led mod. Just before i threw the reflector in the trash i tried it with a SSC P4 LED. It gave a nice focussed beam. So i kept the reflector and got a dome heat sink.
I know some of you guys where so lucky to get one of these LEDs. So the question is: Will a P7 give a nice focussed beam in a MAG 2D reflector or should i use a P4. I dont know if its worth waiting till the P7 come available.
Thanks for reading! Worldedit
The beam would be wider due to the larger emitting surface(4x larger). The P4 would give you a narrower beam.
how would one even drive one of these from a 12v power source? are there any drivers that will output this type of amperage ?
Seems like the P7 is just small enough to fit in the Mag reflektor.
I made a beamshot with my LF2 SSC without head in Mag reflector and L2D-ce Cree P4 smooth reflector. Both were on low setting, nearly the same overall output. Hot spots are nearly the same size, while the LF2 Mag´s is brighter. You cant see any spill because its very little and even.
I would use 2 or 3 boards to power a P7. But i still dont like it beeing wired parallel.
The P7 will not properly focus in a Smooth or Orange Peel reflector. You need a Medium Stipple to completely eliminate the donut hole. Up close the beam on a white will look fine as soon as you reach past 10 feet or so the donut hole is visable even with a Sputtered reflector.
Mac
If you need a reflector for the Aleph3 send me a PM with your shipping address.
I have a spare reflector for free:grin2:.
Thank you very much for your kind gesture.
I don't have a SSC P7 yet but if I get hold of an Aleph L.E with a SSC P7 and
you still have the reflector, I may PM you. :thanks:
No problem, then I'll send the reflector to DaFabricata.
He has two Seoul P7 and want the reflector for a mod too.
And I think he will us updated with his work:grin2:.
@DaFacricata - I'll send you a PM:).
In the name of research and development, I can't think of a better
CPFer to send it to. :twothumbs
Thank you for the kind words!
I will see how this works and report back with my findings!;)
These P7's are REALLY BRIGHT!!
I wonder what reflectors are going to work for these new LED's
Hopefully this will!
PM sent with shipping info...Thanks Again!:wave:
