GoVegan
Streamlight has released a new Stinger upgrade, more lumens, better ergonomics, a little bit shorter and a little bit lighter compared to the Stinger DS LED.
https://www.streamlight.com/en/products/detail/index/stinger-2020
https://www.streamlight.com/docs/default-source/fact-sheet/355.pdf
Videos:
Streamlight Stinger® 2020: The Next Evolution in Work-Ready Lighting Tools
https://www.youtube.com/watch?v=-pg7O6jtjg4
Streamlight Stinger® 2020: The Next Evolution in Duty-Ready Flashlights
https://www.youtube.com/watch?v=Z_v7P7aW6js
My opinion:
It looks nice, but they have now gone the down the route of trying to compete in the lumen wars, I'm guessing because they are seeing Olight eat some of their market.
Looking at the runtime chart, it shows the high of 2000 lumens drops down to half within mins, so if you are using the light on high for short bursts you'll only get less than 1 hour, which sucks.
Personally I liked the older regulated chart for longer runtime on high, so your light doesn't die right at the start of a 10 hour shift.
Stinger DS LED:
https://www.streamlight.com/docs/default-source/fact-sheet/201.pdf
I think this light will be popular with those that want all the lumens, but I think a better choice for most officers would be the ASP XT DF. Better quality, longer runtimes, better UI, great belt case, 18650, CR123 backup.
- High, medium and low modes plus strobe:
- High for a high lumen beam: 2,000 lumens; 315m beam; runs 2 hours
- Medium for bright light & longer run time: 850 lumens; 200m beam; runs 4 hours
- Low for extended run time: 100 lumens; 70m beam; runs 24 hours
- Strobe for disorienting or signaling: runs 3.25 hours
- Intuitive mode switch for easy selection of High, Medium or Low
- "Set and forget it" - no need to cycle through the settings to get to the desired mode
- Features Independently functioning head-mounted and tail switches
- Uses two SL-B26™ protected Li-Ion USB rechargeable battery packs
- Charge with existing Stinger chargers, USB cord or lithium ion bank charger
- Aluminum alloy body with ergonomic, anti-roll body design and textured grip
- Corrosion resistant, gasket-sealed Borofloat® glass lens
- IPX7 waterproof; 2m impact resistance tested
- 7.67" (19.48 cm); 12.3 oz (350g)
- TAA Compliant
- Limited lifetime warranty
Videos:
My opinion:
Stinger DS LED:
