LED-holic
Ok it's been almost a week since I got the D10 and playing with it non-stop. It's a great great light, and I love using it. This is about as close to "the ultimate light" for me so far.
However, if the world was perfect, and I could change a couple things with it to make it even greater, here's what I would change:
1. instead of click-hold to go to max, change it so click-click goes to min / max on alternate cycles. For example, if I want min, click click. If I want max, click-click again, and boom it goes to max.
This would seem easier than click-press/hold. I find myself trying to go to max by "click-click" than doing the "click-press" at times, and vice versa with trying to go to min. If it alternated from min to max with click-click, it would take less time, less effort, and less mental thought.
2. make the user adjustable setting a constant memory. In other words, the user adjustable setting is not lost when you go to min or max. So every time you single click, it goes to your last setting. To go to low, click-click, to go to max, click-click again. Simple and easy to use.
3. Make the ramp setting smarter. If you're at min, and you press and hold the button to ramp, it will automatically ramp up every time. Same if it's on max, it will ramp down every time. No need to worry about if it's ramping down when you're already on min, and ramping up when you're at max.
These suggestions would make this great light even greater imho. But as it exists right now it's very close to perfection and I do love using it! :thumbsup:
