Hi boys and girls !
Here's my little preview of Don't upcoming SunDrop evolution: the SunDrop-3S.
For starters, here's a picture comparing a classic SD and a SD-3S:
As you can see, you can't see any difference.
The magic is in the new driver Don uses for the 3S head. The body is the same for the two, it is a titanium McClicky 1x123 body with Don's "death grip" ti clip, as usual.
Here's a pic of the 3S-head:
The new driver offers 3 levels of brightness and nothing else, no strobe, no SOS and no fancy blinky modes. It uses PWM as method of dimming which means the color of the beam is always the same on all levels.
The drive current is the same as the original SunDrop, and for the three levels Don measured:
High 48 lm
Med 13 lm
Low 3 lm
The luminous flux is lower than the typical light using a Cree or SSC LED as the High-CRI LEDs aren't as efficient as the standard white LEDs.
For more info from the horse's mouth read this thread where Peter Atwood first revealed the existence of the super-secret instrument of light Don was planning
http://www.candlepowerforums.com/vb/showthread.php?t=209635
All this does sound very good, there's more in the same package, after all. But then comes the UI. And usually, when there's a lot of options hiding behind one button, the UI is the deal breaker. At least it is for people like me who are obviously unwilling to dive further into th erealm of lights that require a manual and a learning curve.
Well, I overcame my fear and pressed the button and used the light. :candle:
The UI in this one is pretty simple. Press for "on" at the level you had it before, meaning it has a memory for the last level used. Press for "off". To change levels, simply blink the light once (you can do that without latching the McClicky switch) to enter the next level. The light cycles from dim to bright endlessly. And that's it.
If you blink slower than about 0,5seconds or so, it won't change levels but simply go on and off. There's no programming, no easter eggs and no menue. Nothing.
In the end, I miss the momentary option and especially the momentary high. But then again, I have always something negative to say :green:
Apart from that, the UI is very much KISS and really easy to get used to. No manual required, nothing can go wrong, I can even lend the light to my wife without having to worry about her messing up my light.
I have to say that for the SunDrop the merits of the 3S-driver outweigh the flaws by far, and the flaws are very few in number anyway. I prefer the 3S now that I have both. And that means a lot from my mouth as I really can't stand UIs.
I did some beamshots comparing the SD-3S to other lights. I tried to chose adequate opponents from my littel inventory, and came up with those three lights that will fight it out:
A Zebralight H30 seems the perfect choice as it has a very similar beam pattern, three power levels and everybody seems to have one. Then, a Photon Freedom with the Nichia GS LED will challenge the SD-3S.
All pics are the same exposure which explains the drastic difference in brightness. A camera isn't as good as the human eye. White balance is "daylight" and all settings are fixed.
Note the very warm and "High-CRI"-color of the SD versus the cool and somewhat green touch of the others. Of course, the camera overexaggerates this by a large margin :green:
The SD-3S is always on the left, and it starts with the H30 on the right ... going from low --> med --> high:
Then the Photon Freedom, which is always on max brightness:
High level is just like the classic SunDrop.
Medium is a useful general level with supposedly great runtime.
Low is interesting. When used for walking indoors, it provides are very dim and broad illumination of the surroundings. When used up close, it is easily bright enough to read or study a map, and it is also bright enough to endanger your night vision.
This low level is a very useful work horse, but it is not a find-me beacon of super-duper low. The followers of the "Super-Low Cult"
must know this before purchasing.
The end result is:
1) I am pleased with the light. I think it is a very nice improvement over the standard SunDrop.
2) Don has invested all this time and effort to build a light from scratch that gets stomped by a Photon Microlight :nana:
3) We absolutely need a SunDrop-T for "tacticool" that has a secondary menu with a force-mode for full birghtness and a seizure-inducing strobe at 17 Hz
bernie
High 48 lm
Med 13 lm
Low 3 lm
The end result is:
bernie
