Super Bulb usage update request.
Icebreak
by the river
<font color="purple">*Edit* Some guys are giving calculated lumens so I'm adding two fields, RLumens(rated) and CLumens(calculated). Include those if you wish. We may need a couple other fields later but I can do that by breaking up the Discription field</font>
<font color="green">*Edit 01/11/05* I'll start updating the first post so you don't have to copy/paste/edit like a sign up list</font>
Quite a while back, FlashlightOCD thought it would be a good idea for members to post what bulbs they used with what host/battery configurations in the form of a list.
For a while I tracked this list in the form of a table. I've done a terrible job at updating the table so I wanted to ask if the HotWire folks would update the table with their discoveries.
There are plans in motion to build a much more useful SuperBulb table that may use information from my ugly little table. This will be done by one or more members that are much more expert than I. In the meantime it's nice to have it as a readily available Word document, Excel spreadsheet or Access table/query/report.
The structure is Reporting Member, Bulb, Volt Rating, Amp Rating,<font color="red">RLumens,CLumens</font> and Description. If you don't readily remember V or A don't worry about it. I suspect that "Discription" will be split into three fields; Batteries, Host and Comments. Maybe Resistance, VDrop and Run Time will also be separate fields in the future. I would like to keep the first field, "Reporting Member" because it is the best unique ID. If we maintain a unique ID then DB manipulation and queries will be easier. If we stick with the structure then I can much more easily create a CSV for the project. I want to clarify that I'm not the lead on the project. I'm just attempting to gather useful, well structured information for the project.
I know this is a lot to ask but the resulting work done by one or more experts will save us all hundreds of answer posts. Plus, I can barely remember the specs on just a few bulb/usage configurations. Also, if this is a rotten idea or too much of a PITA; that's cool. It's understandable.
But if you feel like it, please copy/add/edit/paste your submissions to the following table and then post it like we do in a sign-up thread. Except, this will be an "I've been there and done this" thread.
Thanks -
- Jeff
Ginseng:
WA01318 (9.6V, 1.93A): Mag3C on 5x123 lith, Mag4C on 4.5 and 5x123 lith, Mag3D on 9xAA nimh, Mag3D 10xAA nimh in 2x modified EL 3-D holders (reduced resistance) and 1xRS 4AA holder also heavily modified for lower resistance and fit Designated “MoMag”.
WA01185 (9.6V, 3.15A): Mag3D on 9xAA nimh, Mag3D 10xAA nimh in 2x modified EL 3-D holders (reduced resistance) and 1xRS 4AA holder also heavily modified for lower resistance and fit
WA01274 (7.2V, 2.77A): Mag2D on 6xAA nimh, Mag3D on 6xAA nimh + 1D alkie
CA809: Mag3C on 4x123, Mag4C on 4.5x123
CA805: Mag3D on 3xD alkie, Mag3C on 3xC alkie
CA717: Mag3D on 4x123 lith, acid etched bulb
HPR51: on 3x123
CA1057: on 3x123 (brighter than HPR51).
Lemlux:
WA01319: UK D4
WA01111: MagCharger
WA01160: MagCharger
WA01317: DB8AA
WA01148: DB4AA on 6x123 lith
FlashlightOCD:
WA01160 + MagCharger = Very bright rechargeable light that will outperform a Tigerlight, with an output of about 500 lumens.
Phaserburn:
WA01160 + Powerstream 1/2D batts + MagCharger = runtime of 45-55.
Big D bulb 7.2V high nicad version*, 6V, 4A,,600 lumens, 24W Mag 2D 6 Nimh AA in 2 EL 3 to D holders
Tech A Billy:
WA01315: (6.27v 1.42A). Energizer 4AA Double Barrel modified to use six SF123's. Runs at 7.2 volts for over 250 lumens with a beam that’s nice and tight but not surefire perfect.
WA01286: (4.2v .70A) Energizer 4AAA modified with the DB6AA bulb - 4 NiMH AAA's in series - 70 lumens.
S4MadMan:
WA01660: MAG Charger - PowerStream 1/2Ds - recorded run times of 50-50-49-50 minutes.
WA01660+ Mag + Super WMP (WilkeyMagPack) with UCL vs. Tiger light FBOP + TL approved replacement lamp and batt pack + UCL
Icebreak:
KPR118: (7.2v 700mA) Mag 3D - 9 slightly used AAs @ 1.4v - 3 unmodified E.L. 3toD canisters for 12.6v - est. resistance 3X 1.25 Ohm. Beam =>2X as bright and hot spot is 2X as large as the original configuration.
WA01185 (9.6V, 3.15A): Mag3D on 5X123. Melted stock reflector in 2 minutes. Needs a PMR or a modified Aluminum Carley reflector.
Ailsnail:
WA1318 in mag 3c on 4 x 123 + 1 x E2
WA1274 in mag 3c on four partly spent 123's.
soloco: (as a CSV)
DB configs. and TB config, in response to 3A WA
CA808,,,2x4 123s in a 3D
WA1185,9.6V,3.15A,3x4 CR2s in a 2D
WA1274,7.2V,2.77A,2x3 123s in a 2D
MR16 20W,12V,~2A,5x2 123
WA1166,,,5x2 123 highest light efficacy I've seen. It's actually slightly underdriven with 10 123s in a 5x2 config. It's perfectly driven by 6 123s in series. I'm using Voltage per Cell = -0.4159 * Current + 3 in all my 123 calculations.
Alan L:
CA717: Mag3D with 9 NiMH AAs in unmodified EL 3-to-D adapters.
Litho123:
The WA01318 I have has been running great @ 2 stacks of 4x123 with a calculated runtime of over 70 minutes.
Hookd_On_Photons:
Pelican Big D Rechargeable (6V SLA version) high-output bulb: Mag2D with 7 (or 8) NiMH AAs in a fivemega 8AA-to-2D adapter. Calculated output: 7 cells - 1029 lumens, 8 cells - 1642 lumens (vs. Mag60 - 1041 lumens)
JimH:
CL606 - Mag4D with alkalines, or any other form factor that gets you 6v. Calculated lumens 516.
GH24 - Mag 2C with 2 Pila 150A's. Calculated lumens = 418
WA1185 - Mag 4C with 3 Pila 168A's. Calculated lumens = 1234. Need metal reflector and borofloat lens
Bwaites:
CA1499- 2C with 3x123
Reflectalite GH24- 2C with 3x123
WA1111- 2C with 6xAA NiMH (MrBulk Assault and Batteries)
2D with 2 3AA to D
WA1160- Magcharger with 5 1/2D NiMH or NiCad
3C with 5x1/2 SubC
WA1185- MagCharger or Mag3D with custom made 9AA stick pack or
3 3AA-to-D Elektrolumen adaptors.
WA1274- Mag2D with 2 3AA-to-D or Mag3D with 3 3AA-to-D and
running 7 cells and 2 dummies.
Kiu:
Philips Foucsline 7388: 6V, 20W with 2X EL3AAtoD. By nake eye, the beam is almost the same with mag60. But this bulb have 100hrs life @6v.
Philips Foucsline 7023: 12V, 100W with 12AA for short burst
Snoopy:
Osram 64625 HLX (12V, 8.33A, 3600lm): Maglite 4D body with 2×10AA NiMh direct drive
Osram 64275 AX (6V, 5.83A, 780lm): Maglite 3D body with 5×1/2D NiCd direct drive
MoonRise:
CA1499(potted) - Mag 2C with 3x123 , measured current = 1.7A (12-15W taking into account voltage sag under load), short bursts or short runtime OK with stock Mag plastic reflector and lens, longer runs recommended to use metal reflector and glass lens. Reported to instaflash (by litho123 and/or bwaites) on twin-stack of 3x123 (not enough voltage sag, hence instaflash). Will light up an entire house front at 100 yards, 35 foot diameter hot spot and usable at that distance.
Ginseng:
HPR51: on 3x123
Lemlux:
WA01319: UK D4
WA01111: MagCharger
WA01160: MagCharger
WA01317: DB8AA
FlashlightOCD:
Phaserburn:
Tech A Billy:
WA01286: (4.2v .70A) Energizer 4AAA modified with the DB6AA bulb - 4 NiMH AAA's in series – 70 lumens.
S4MadMan:
WA01660: MAG Charger - PowerStream 1/2Ds – recorded run times of 50-50-49-50 minutes.
Icebreak:
KPR118: (7.2v 700mA) Mag 3D – 9 slightly used AAs @ 1.4v – 3 unmodified E.L. 3toD canisters for 12.6v – est. resistance 3X 1.25 Ohm. Beam =>2X as bright and hot spot is 2X as large as the original configuration.
Ailsnail:
soloco: (as a CSV)
Alan L:
Litho123:
Hookd_On_Photons:
Comments (please clip this when adding to the table):
Output is comparable to a Mag60 and it's a readily available, high-output, PR base bulb. Calculated output overdriven with 7 cells is 1029 lumens. On 8 cells, calculated output is about 1642 lumens. The calculated output of a Mag60 is 1041 lumens.
Beamshots included in this thread:
Pelican Big D bulb thread
Ah, thanks, Hooked. That's one we definitely needed.
I like your idea of a comment section for each post. Maybe R lumens and C lumens should be capture fields as well? Easy enough to do this if we wish.
It would be nice if there were no duplicates and the bulbs were in numerical order if there were no differences in the way they are run.
IE.
1111- 3x123 or 6xNiMH AA
1160- 5 x 1/2D NiMH
and so on.
If a new bulb is added in between two already existing its easy to see.
Bill
Ginseng:
HPR51: on 3x123
Lemlux:
WA01319: UK D4
WA01111: MagCharger
WA01160: MagCharger
WA01317: DB8AA
FlashlightOCD:
Phaserburn:
Tech A Billy:
S4MadMan:
Icebreak:
Ailsnail:
soloco: (as a CSV)
Alan L:
Litho123:
Hookd_On_Photons:
JimH:
WA1185 - Mag 4C with 3 Pila 168A's. Calculated lumens = 1234. Need metal reflector and borofloat lens.
Thanks, Jim! /ubbthreads/images/graemlins/wink2.gif
Yeah, I like the calculated lumens. I guess I'm going to have to learn how to do cubes. I'm always off just little.
[ QUOTE ]
[/ QUOTE ]
Yes, absolutely Bill, I would agree that's probably the best way to be able to read the final output. Though, some folks may want it sorted by battery type. For me, the duplicates are useful because the more people that find a configuration to work, the more tested and reliable it is. It's because of this that I would like to encourage everyone to submit all or most of their experiences even if they see someone already did the same thing. Basically, I just want to deliver good information to the fellows actually doing the project in such a way that they can easily do what they please.
Having a more normalized output table like what you are describing is what humans naturally want to see. What I'm attempting to do here is data capture into an input table. Once we have the data we can manipulate the criteria as we wish, including grouping on battery configs to eliminate duplicates and sort ascending on Bulb Type. Ultimately, I would guess the folks doing it might make it interactive.
BTW, they are CPFers and I’m sure you know one of them.
The real challenge in the beginning is just getting the data.
I SAY, THE REAL CHALLENGE IN THE BEGINNING IS… Ahem. /ubbthreads/images/graemlins/poke2.gif /ubbthreads/images/graemlins/smile.gif
- Jeff
Thanks Icebreak, I thought this was going to serve as the source, but re-reading your first post I see what you meant now!
I'll post my stuff tonite!
Bill
Whoever posts the next update:
Please give phaserburn credit for the Pelican Big D bulb. He's the one who started the thread about it. I just tested the bulb with various battery configurations and took some beamshots. If this is all going into some archival database, then I don't want credit for a "discovery" I didn't actually make. I thought this was just an "I tried this, and it works" list.
[ QUOTE ]
[/ QUOTE ]
Hooked, the way I understand it, you are correct in your assumption. Icebreak is in the data collection mode (i.e. "I tried this, and it works"). At some later point, he is going to try to put it all together in a form that is more usable to a variety of interests.
So, whatever combinations of Big D bulbs and batteries that you have tried, and seem to work well, would be valuable input. Just post what you have, and Icebreak will take it from there.
Yes, Hookd_On_Photons and JimH, you are both correct. The order is just what I picked up along with who posted to FlashlighOCD's original thread so, the order really doesn't have a method. I think legacy might be a bit of a challenge but if ya'll want to try it I'm game. I went ahead and added a record for Phaserburn and put an asteric next to the bulb.
I thought some of you might like to have the Comma Separated Value (CSV) version to mess with. You can copy it to a .txt file then import it into Excel. Or, what I've been doing is importing it into Access then using Access to export it to an Excel spreadsheet. As an .xls sheet you can sort it as you please. As an .mdb you can query it as you please. When I split the "Discription" field up we will be able to do even more. If you come up with ideas on how output tables should look, by all means let me know.
*edited to try to kill scrolling*
Back to our regularly scheduled table.
Ginseng:
HPR51: on 3x123
Lemlux:
WA01319: UK D4
WA01111: MagCharger
WA01160: MagCharger
WA01317: DB8AA
FlashlightOCD:
Phaserburn:
Big D bulb 7.2V high nicad version*, 6V, 4A,,600 lumens,Mag 2D 6 Nimh AA in 2 EL 3 to D holders
Tech A Billy:
S4MadMan:
Icebreak:
Ailsnail:
soloco: (as a CSV)
Alan L:
Litho123:
Hookd_On_Photons:
JimH:
Ginseng,,,,,,
Ginseng,WA01318,9.6V,1.93A,,,Mag3C on 5x123 lith Mag4C on 4.5 and 5x123 lith Mag3D on 9xAA nimh Mag3D 10xAA nimh in 2x modified EL 3-D holders (reduced resistance) and 1xRS 4AA holder also heavily modified for lower resistance and fit Designated "MoMag".
Ginseng,WA01185,9.6V,3.15A,,,Mag3D on 9xAA nimh Mag3D 10xAA nimh in 2x modified EL 3-D holders (reduced resistance) and 1xRS 4AA holder also heavily modified for lower resistance and fit
Ginseng,WA01274,7.2V,2.77A,,,Mag2D on 6xAA nimh Mag3D on 6xAA nimh + 1D alkie
Ginseng,CA809,,,,,Mag3C on 4x123 Mag4C on 4.5x123
Ginseng,CA805,,,,,Mag3D on 3xD alkie Mag3C on 3xC alkie
Ginseng,CA717,,,,,Mag3D on 4x123 lith acid etched bulb
Ginseng,HPR51,,,,,on 3x123
Ginseng,CA1057,,,,,on 3x123 (brighter than HPR51).
Lemlux,,,,,,
Lemlux,WA01319,,,,,UK D4
Lemlux,WA01111,,,,,MagCharger
Lemlux,WA01160,,,,,MagCharger
Lemlux,WA01317,,,,,DB8AA
Lemlux,WA01148,,,,,DB4AA on 6x123 lith
FlashlightOCD,,,,,,
FlashlightOCD,WA01160,,,,,MagCharger = Very bright rechargeable light that will outperform a Tigerlight with an output of about 500 lumens.
Phaserburn,,,,,,
Phaserburn,WA01160,,,,,Powerstream 1/2D batts + MagCharger = runtime of 45-55.
Phaserburn,Big D bulb 7.2V high nicad version*, 6V, 4A,,,Mag 2D 6 Nimh AA in 2 EL 3 to D holders
Tech A Billy,,,,,,
Tech A Billy,WA01315,6.27v,1.42A,,,Energizer 4AA Double Barrel modified to use six SF123's. Runs at 7.2 volts for over 250 lumens with a beam that's nice and tight but not surefire perfect.
Tech A Billy,WA01286,4.2v,.70A,,,Energizer 4AAA modified with the DB6AA bulb - 4 NiMH AAA's in series - 70 lumens.
S4MadMan,,,,,,
S4MadMan,WA01660,,,,,MAG Charger - PowerStream 1/2Ds - recorded run times of 50-50-49-50 minutes.
S4MadMan,WA01660,,,,,Mag + Super WMP (WilkeyMagPack) with UCL.
Icebreak,,,,,,
Icebreak,KPR118,7.2v,700Ma,,,Mag 3D - 9 slightly used Aas @ 1.4v - 3 unmodified E.L. 3toD canisters for 12.6v - est. resistance 3X 1.25 Ohm. Beam =>2X as bright and hot spot is 2X as large as the original configuration.
Icebreak,WA01185,9.6V,3.15A,,,Mag3D on 5X123. Melted stock reflector in 2 minutes. Needs a PMR or a modified Aluminum Carley reflector. Now running 3 EL 3toD VS2 cannisters with cammed MOP PMR with good success.
Ailsnail,,,,,,
Ailsnail,WA1318,9.6V,1.93A,,,in mag 3c on 4 x 123 + 1 x E2
Ailsnail,WA1274,7.2V,2.77A,,,in mag 3c on four partly spent 123's.
Soloco,,,,,,
Soloco,CA808,,,,,2x4 123s in a 3D
Soloco,WA1185,9.6V,3.15A,,,3x4 CR2s in a 2D
Soloco,WA1274,7.2V,2.77A,,,2x3 123s in a 2D
Soloco,MR16 20W,12V,~2A,,,5x2 123
Soloco,WA1166,,,,,5x2 123 highest light efficacy I've seen. It's actually slightly underdriven with 10 123s in a 5x2 config. It's perfectly driven by 6 123s in series. I'm using Voltage per Cell = -0.4159 * Current + 3 in all my 123 calculations.
Alan L,,,,,,
Alan L,CA717,,,,,Mag3D with 9 NiMH AAs in unmodified 3-to-D adapters.
Litho123,,,,,,
Litho123,WA01318,,,,,2 stacks of 4x123 with a calculated runtime of over 70 minutes.
Hookd_On_Photons,,,,,,
Hookd_On_Photons,Pelican Big D Rechargeable (6V SLA version) high-output bulb,6v,,,7 cells - 1029 lumens/ 8 cells - 1642 lumens,Mag2D with 7 (or 8) NiMH AAs in a fivemega 8AA-to-2D adapter. Calculated output: 7 cells - 1029 lumens, 8 cells - 1642 lumens (vs. Mag60 - 1041 lumens)
JimH,,,,,,
JimH,CL606,,,,Calculated lumens 516,Mag4D with alkalines or any other form factor that gets you 6v. Calculated lumens 516.
JimH,GH24,,,,Calculated lumens = 418,Mag 2C with 2 Pila 150A's. Calculated lumens = 418
JimH,WA1185,,,, Calculated lumens = 1234,Mag 4C with 3 Pila 168A's. Calculated lumens = 1234. Need metal reflector and borofloat lens.
Ginseng:
HPR51: on 3x123
Lemlux:
WA01319: UK D4
WA01111: MagCharger
WA01160: MagCharger
WA01317: DB8AA
FlashlightOCD:
Phaserburn:
Tech A Billy:
S4MadMan:
Icebreak:
Ailsnail:
soloco: (as a CSV)
Alan L:
Litho123:
Hookd_On_Photons:
JimH:
Bwaites-
Carley
1499- 2C with 3x123
Reflectalite
GH24- 2C with 3x123
Welch Allyn
2D with 2 3AA to D
3C with 5x1/2 SubC
Bill
Any other tried the Philips Foucsline bulbs?
I am using the 6V 20W(7388) with 2X EL3AAtoD. By nake eye, the beam is almost the same with mag60. But this bulb have 100hrs life @6v.
And I am using the 12V100W(7023) with 12AA for short burst.
Phillips Focusline Microprojection Lamps
Sorry, **edited** for the hyperlink /ubbthreads/images/graemlins/tongue.gif
Ginseng,,,,,,
Lemlux,,,,,,
FlashlightOCD,,,,,,
Phaserburn,,,,,,
Tech A Billy,,,,,,
S4MadMan,,,,,,
Icebreak,,,,,,
Ailsnail,,,,,,
Soloco,,,,,,
Alan L,,,,,,
Litho123,,,,,,
JimH,,,,,,
Snoopy, Osram 64625 HLX, 12V, 8.33A, 3600lm, -, Maglite 4D body with 2×10AA NiMh direct drive
Snoopy, Osram 64275 AX, 6V, 5.83A, 780lm, -, Maglite 3D body with 5×1/2D NiCd direct drive
Ginseng:
HPR51: on 3x123
Lemlux:
WA01319: UK D4
WA01111: MagCharger
WA01160: MagCharger
WA01317: DB8AA
FlashlightOCD:
Phaserburn:
Tech A Billy:
S4MadMan:
Icebreak:
Ailsnail:
soloco: (as a CSV)
Alan L:
Litho123:
Hookd_On_Photons:
JimH:
Bwaites-
Carley
1499- 2C with 3x123
Reflectalite
GH24- 2C with 3x123
Welch Allyn
2D with 2 3AA to D
3C with 5x1/2 SubC
Snoopy:
Regards,
Snoopy
*edit*
Snoopy -
I was composing while you were posting.
If anyone wants to post to the text and the CSV, that's actually pretty helpful. Only caveat I can see is the thread might get a little scrolly. Maybe the thread starts to use too much bandwidth? What do you guys think?
BTW Snoopy, I guess you knew that you nailed the CSV. Thanks!
Ginseng,,,,,,
Lemlux,,,,,,
FlashlightOCD,,,,,,
Phaserburn,,,,,,
Tech A Billy,,,,,,
S4MadMan,,,,,,
Icebreak,,,,,,
Ailsnail,,,,,,
Soloco,,,,,,
Alan L,,,,,,
Litho123,,,,,,
JimH,,,,,,
Ginseng:
HPR51: on 3x123
Lemlux:
WA01319: UK D4
WA01111: MagCharger
WA01160: MagCharger
WA01317: DB8AA
FlashlightOCD:
Phaserburn:
Tech A Billy:
S4MadMan:
Icebreak:
Ailsnail:
soloco: (as a CSV)
Alan L:
Litho123:
Hookd_On_Photons:
JimH:
Bwaites:
2D with 2 3AA to D
3C with 5x1/2 SubC
Kiu:
Snoopy:
This is great! You guys will see a much nicer presentaion of this information in the near future. Let's just say the center of the Hot Wire Galaxy is starting to coalesce. /ubbthreads/images/graemlins/grin.gif
Wilkey
MoonRise:
Carley 1499 (potted) - Mag 2C with 3x123 , measured current = 1.7A (12-15W taking into account voltage sag under load), short bursts or short runtime OK with stock Mag plastic reflector and lens, longer runs recommended to use metal reflector and glass lens. Reported to instaflash (by litho123 and/or bwaites) on twin-stack of 3x123 (not enough voltage sag, hence instaflash). Will light up an entire house front at 100 yards, 35 foot diameter hot spot and usable at that distance.
Comment: The cut-n-paste of the entire table by each new contributor is making the page get a bit unwieldy and scrolly. Suggest that Icebreak have the master table at the top of the page and re-edit the table to reflect each contribution.
I'll do just that. This will make it easier on everyone I think.
I think the CSV was making it a little scrolly but I suspect it is Kiu's hyperlink to be the big culprit.
Remember all, the closer your submissions are to this format the better:
<font color="blue">
Reporting Member:
Bulb, Volt Rating, Amp Rating, RLumens, CLumens : Description
</font>
Description should have at least the battery configuration. Host is good to know. Watts, runtime and anything else you think is specifically relevant are welcome in that field also. Will sort it out later.
Also, any suggestions on how to make this easier or the output useful to you are encouraged.
Most importantly, the man behind the curtain has revealed his identity.
