This thread caused me to dust off an A2 for the evening jaunt.
The light will function without the LED ring. You can remove it if it bothers you too much. Might even gain a little tiny piece of runtime too.
Sure, because blue and purple tinted LED's really help to enhance that 3350K A2 beam's CCT whiteness :thinking:
Is this the part where you repeat the same demonstrably false claim that I've seen you post over and over again, year after year in reading old threads? About how the A2's beam is "too orange" and how it's "not as white as other SF lights".
Last time we had this conversation, you said you were going to "post some beamshots to prove your point". Perhaps you feel these aren't needed anymore, as you have already "disproven" this many times through your own observations?
Personally, I've compared the A2 against more Surefire Incandescent lights, bulbs and combos than I care to even think about, and the CCT and whiteness of the A2 never fails to impress.
There are a few beamshots in JS's original A2 review here. If you compare them with the E2E and MN03, for example, one can clearly the superiority of the A2's CCT.
I would love to hear exactly what combination of bulb and battery you use to determine that the A2's beam is "too orange", "not driven hard enough" or whatever conclusion you came up with.
Perhaps the secret combo of gasses in the P60 and E bulbs burns brighter than the A2 so that when voltage is running down they won't appear so orange where the regulated A2 bulb stays consitant since it's regulated.
I do remember PK saying once that they spent a while computing potential combinations in order to achieve an over drive look while achieving more lifespan. He said at one point the earlier P60 bulb would often times poof before the batteries were depleted. He hired a Phd fellow to design the gas combo. He said the Phd fellow told him he needed a better computer because it took 5 computers a week each to solve some of the equations so SureFire spent a bunch of money on a better computer so it wouldn't take so long to come up with potential combos to try in a test batch. They set the stage for others later to have truely "educated guesses" instead of blind faith trial and error.
I guess if it has bothered you for so long and in so many ways, you could easily post something to refute what I have been saying. Maybe if I feel like it I'll post some photos, I do need to do some maintenance one one of my A2's, but it's not a priority. I'm not saying you're wrong, or I'm right irrefutably, but you could contribute as well. I did just look at an A2 vs. a P60 with not so fresh batteries and yes, the P60 does have a whiter beam. And so does my beat up carry E2e/MN03 on not so fresh primaries. I'm pretty sure both lamp assemblies are driven harder than the A2's, and they certainly put out more light.I'm an avid reader of thread's on the A2, which is collected together here in this index. I never had, or intend to personally "attack" you on the subject, but when I see something that is demonstrably, verifiability false repeated over, and over, and over again across all the different threads I've read, I stand it's reasonable to call that out. And I will attempt to do that by here by "attacking the post, not the poster" as kindly and wisely suggested earlier.
In that index of reviews, opening just a few of them reveals some comments such as
"The P60 in the G2 has a (barely) nicer beam in terms of shape, but the A2 has got it beat in whiteness."
" The P90 is slightly brighter - though surprisingly, not by a whole lot more, but the A2 is most definitely WHITER. It's whiter than even the P91"
"Compared to the E2e, to my eyes, the output was the same. The A2 was a tad bit whiter and tighter."
That's just the tip of the iceberg when it comes to the user reports of how white the A2's beam is. The whiteness of the beam is one of the greatest attributes of the A2 that we consistently see mentioned by owners.
And we must remember, most of these reports are from people that were running the factory MA02. The lumens factory lamps are a bit brighter than the stock lamp, and the 3718 1.8A Lamp is available from Tad's for even more output.
Furthermore, I would like to hear a dispute to Lumens Factory's own listed specifications. In their specifications page for the A2 here, it's listed as being 3350K. In the specifications for all the D26 modules (aka P60/P90 type) here not one single lamp is listed as high as 3350K, all falling short, even the E0-9 at 380 bulb lumens on Li-ion can only achieve a listing of 3325K. It must be noted that most of these lamps are vastly superior to the P60 running on primaries in terms of sheer output and CCT.Therefore it is impossible for a P60 or MN03, with unfresh batteries mind you, to be whiter than the A2 and MA02. This is assuming there are no physical issues (dirty contacts, old degraded bulb, etc)
And the distance in that photo in JS's review is only 33 feet. That's close enough in my opinion that the CCT difference can still be visible in the photo, and considering the not so big difference between the two lights in throw. Despite that, more than enough evidence exists to show the A2 is very good in the CCT department and better than most.
How the hell does a thread about one dam fine light turn into a pissing match?! Really?
I have a stock Surefire P90 module that is dimmer than any of my stock Surefire P60 modules, regardless of what cells I put in.
I assume I just have a bad module.
I believe sometimes individuals report their individual experiences with an individual item as general fact, and sometimes many times in different places leading to a false appearance of widespread generality - and I can completely understand another's desire to correct the situation.
I have also learned that it is true that literally every person's eyes are different, and that some battles we will never "win" in trying to "correct" a difference in perception/opinion.
On topic, I have never wanted an A2 more than since this thread started.
Maybe too much faith in reviews and not so much personal experience. Seems like this is fuel for another thread. I'll post some pics and create a new one so as not to get this one off track. I have had the lumens factory version of the MA02 bulb as well, including the short run of unfrosted bulbs. They are slightly brighter than the stock bulb. CCT is also affected by brightness and at that distance with the larger reflector the A2 has more brightness than the E2e. Lights that throw better appear brighter to the average user. 33 feet is a long ways for an E2e with a typical reflector. Some are less orange peel than others, but the typical E2e reflector is a short range light.
