chillinn
It's unfortunate that there are so few (any?) options for appropriate rechargeable cell options for the MN02 and MN03.
They both work in single cell Li-ion secondary setup. Many have said this is bad for these lamps, causes darkening glass they say, shortens the life of the lamp they say. But I have never noticed any such thing. Maybe that might happen with a single primary, but a single Li-ion secondary voltage discharge curve is within the same voltage range as that of two Lithium primaries. The worst thing I have seen about running them this way on a single Li-ion secondary is the color temperature gets too warm... but you'll only notice that for short time until the natural white point recalibrator in our brains kicks in. MN03 are far more plentiful than MN01, so I would wager most used E1e you find will have a MN03 in it rather than the stock MN01.
That's not an entirely accurate representation of those lamps. The MN02 also came in a dark blue base...
I have never seen one as light blue as in that picture, and I have thought about this before and suspect the image is color-uncorrected simply to show that it is blue, otherwise it might look black in a photo.
I think some certain models of those old colored bulbs are notorious for exploding in the head. Can't remember which one's, or if it was just one.
EDIT: To clarify, it was an M-Series bulb.
I have been running MN02 on a single Li-ion secondary for dozens and dozens of hours, days and days, really, have not seen even one MN02 die, but I am possibly slightly under-driving them. I have ed MN03 many times, always my mistake, absent-mindedly using 2 Li-ion secondaries. I have killed 2x MN01, no mistakes, bought used and I used them until they just stopped working. I have never seen any of the MN explode, but it's not like I'm a pro or anything, no extreme usage with recommended cells. I like to underdrive.
