Surefire E1e, 260 emitter lumen
Energie
Germany
A small pocket rocket with a Seoul P4 U2..., a
GD1000 driver and an uncut McR20S reflector.
240-280 emitter lumen (Seoul data sheet)
1 A to the Led
Runtime 75 min. with CR123, 40 min. with RCR123
Surefire E1e
Size comparison:
Surefire E1L / KX1, E1e, Novatac
The plan:
The parts:
McR20S-reflector
Driver
Reflector, centering-ring/heatsink
and driver-pill assembled
The pics are some steps underexposed
Surefire E1e with MN01
Surefire E1L with KX1 (on high)
Surefire E1e, modified
I like that A LOT!!:thumbsup::eek:oo:
If you make any more emitter heatsinks and driver heatsinks I would gladly buy a few depending on price.
I have a modded E1e using a Seoul and a cheap driver and simply have an E-can and used a penny as a heatsink. It also uses an Mcr20s. The LED does not stay centered to well.
Is the led module locked in some way or can it fall out from the back? :thinking: ?
Thanks for the kind words!
The led module fits into the head without any play
and there is a small amount of arctic silver between
the head and the centering-ring (good heatsink).
To get it out I use pliers with silicone tips.
