Armadew
Well, I finally replaced my E1E I lost at the airport, but It's giving me problems. It seemed to work fine first out of the box, but after I switched out the tail cap it only works intermittently (even after replacing the original tail cap). I thought it might be dirty contacts so I cleaned them and it seemed to work fine again. It started flickering so I cleaned the contacts a little more, put it back together and nothing. Dead again. Tried different batteries and tail caps, but they don't seem to be the problem either. If it stops working, the only thing that seems to work is taking it apart and putting it back together again repeatedly until it does.
So, do I just need to clean the contacts better? Is there a recommended cleaning solution I should use?
Since it doesn't seem to the tail cap, should I just replace the bulb? I was considering a Lumens Factory drop in anyway.
Thanks in advance.
Thanks in advance.
