Surefire KL4
aingel2k1
Hello, I just needed some help on identification...
How do I tell which version of head I have??
A "KL4 SCC P4" or the "LUX" version?? I'm just curious..
All the head says is KL4....
anyone??:confused:
I believe the Lux version begins with an "A" for the serial number on the head and a "B" for the SSC P4 version.
Failing that, looking into the head the luxV has 4 dies and the SSC has a single die. You will see a faint cross dividing up 4 sections looking down at the LED if its the Lux.
Fletch31
Got it , Thanks guys... its a "single die", but ser# does start with a "A"...
If your's has an "A" on it, maybe you should take a closer look at the following pictures. SSC P4 KL4s are all supposed to be marked "B". The faint division lines of the LuxV are sometimes hard to see.
http://www.candlepowerforums.com/vb/showpost.php?p=2809215&postcount=1 -LuxV is on the left in the first pic
http://www.candlepowerforums.com/vb/showpost.php?p=3290724&postcount=5 -LuxV die is centered in a hexagon, while SSC P4 is centered in a square
Upper pic, P4 on the right, lower pic, P4 on the left...
