petrev
Hi
I have been messing with more options for an M6-Lion system and have so far got these working with C-Lions and waiting for D-Lion cells. All need to use a non-standard HOLA eg. WA11nn +FM.MN-adapter or I am using the FM axial-7.2 at the moment
C-Lions require the AWR short tail insert and a small bit of spring from a Mag-Switch. AWR has lots of the tail inserts but whether he will supply them is another question ! I have a couple and could get more made if there was any real demand ? but as I say AWR has lots ! ! !
If the standard Tail Insert is to be used then the XTN36 or FM short extension will work too with the MagD-spring as below.
Ds will fit with either my XTN36 or the FM short extension and the M6 standard tail insert and a MagD spring (cut down to suit for appropriate pressure)
Pix . . . Short FM-Extension . XTN36 . D-Nicad for size .
Std. M6 Tail-Insert + MagD-Spring . AW C-Lions
M6TailCap . AWR Short Tail-Insert . M6 . 5mm Foam for C-Lions !
Big Picture and the AW C-Lions and FM-Axial 7.2V
D-Cells when available ? ? ? Use these . . .
Any Questions ?
Cheers Pete
Any Questions ?
Cheers Pete
