See below - problem solved - my fault, I twisted too hard on 2 drop-ins.
Hello.
I have (among others) a Surefire G2L.
Today I was holding it, turned on, and suddenly it turned off.
I loosened the tail, tightened again, it came back on, so I didn't think much more of it, maybe I had only tightened the tail just enough.
A short while later, it did the same thing, but this time it wouldn't come back on.
The light is quite new, just a few hours use.
So, 3 obvious causes...
The LED: No, tried it in other lights, works fine. Tried lamps from other lights in this G2L, they don't work. I tried both with the bezel on and tight, and with it removed and just touching the light assembly spring to the batteries while the tail was tight. No luck.
The batteries: No, tried them in other lights, fine, new batteries in G2L don't work.
The tailcap/switch: No, same as the last 2 options, tried the tail/switch on another light, works fine, tried a different tail/switch on this G2L, doesn't work.
All I'm left with to test or to blame is the body, but unless I'm missing something, which I clearly am, the body is not much more than a tube made of nitrolon with some threads at either end, so what is there to "go wrong"?
Other than that I don't know what to say. Batteries, LED, tail/switch, they all work in other lights. Put batteries/LED/tail from other lights to this G2L and it doesn't work.
Any comments or advice would be greatly appreciated.
Hello.
