Surefire claimed a two seconds reset timing on this. Bummer! When they offered a one second reset timing on the E1DL, I was overjoyed and it quickly became my favorite Surefire flashlight. After taking a step forward with the E1DL, they took a step back with the P1R. The video posted above very clearly shows that the light still came on in low output after about a second from off.Will it bounce back to full output each time if only used for short runs?
Sent from my iPhone using Candlepowerforums
If you wait at least a few seconds between runs (need to let the memory drain), it will go back to full output or as much as the battery allows.Will it bounce back to full output each time if only used for short runs?
I think he was referring to resetting the step-down, not changing the output level. Regardless, the reset time for changing output levels is a little bit longer than one second.Surefire claimed a two seconds reset timing on this. Bummer! When they offered a one second reset timing on the E1DL, I was overjoyed and it quickly became my favorite Surefire flashlight. After taking a step forward with the E1DL, they took a step back with the P1R. The video posted above very clearly shows that the light still came on in low output after about a second from off.
Oh yes! My bad! Now that you mentioned, I realized that I had totally misunderstood the question.I think he was referring to resetting the step-down, not changing the output level. Regardless, the reset time for changing output levels is a little bit longer than one second.
The twisty tailcap is a HUGE disappointment. It works great in constant on. However, unlike the 6P, there is no "right spot" that you can freely momentary press as a signal. I tried mm after mm of different loose spots and near every time after I would release from momentary, it would flicker, or seem to remain on at about 1/4 power. The travel of the switch is very very very short and requires A LOT of pressure to activate. I have been using it for about 5 minutes and my thumb is a little sore. The spring connecting to the negative of the battery has a little nub that is also tearing into the battery terminal. There a large gouge in the rear of my battery, and I'm not going to use it anymore. Don't know his thick it is there. My Eagletac's work just fine so I will stick with those. Why wasn't it bent upwards from the factory?
