EDIT: I dialed in that epoxy gap, it is
perfectly even. I checked over the other lights at shot and this seems to be 100% normal variation in manufacturing, but my OCD must have perfection at any cost! The rep explained that when the gap was there that was irrelivant as the threads end at a seal anyway. Good to know, so if you have the same no worries.
OR Post:
30 seconds out of the package it turned black, then the head screwed itself off (easily) and the light started to disassemble itself like something out of transformers.
A few notes: You can see the epoxy inconsistency I was talking about on the bezel, I have tried to force air through the light without luck so it seems it just didn't make it to the edge to fill the gap completely but is still appears well sealed. You may also notice the board itself looks "flaky", I was shocked at first until I realized there is a small amount of adhesive applied to the black shock ring and it's just left over after removal. It seems to be more part of the assembly process to hold the ring there than it is to do so permanently. This is 110% unnoticeable unless you disassemble your head. It also has 0 potential of causing any sort of problem whatsoever so no worries there. The black comes right off and is just an eyesore that you can't see... That said I was amazed at the overall quality of the circuit pill and head itself, it is all self contained and plugs right in like a wall socket. This setup seems VERY robust and easily serviceable should something go wrong. They just pop it open, put a new pill in, close it back up with what is supposed to be locktite
and off it goes. Everything came back together better than when I got it, cleaned and lubed right up. LOVE the light.
I did not take after photos as it was cumbersome to get these up, but the light came together perfectly and thoroughly cleaned and lubed.
