No joy on either the yclo shim method or the alternate force-the-selector-ring method. :(
I seem to have a very recent vintage U2A. It has a Seoul P4 with no plastic sleeve in the bore. And the bore is barely large enough to fit an AW17670 cell (the silver label drags). The selector ring seems very tightly fitted (and stiff to rotate), with barely any gap available to insert an Xacto knife blade or soda can shims.
I tried to muscle the selector ring to jump the aluminum stop by going past the minimum setting, but that didn't work either. Used some bike tubing for grip on the head and the ring.
Any words of wisdom, such as use a bigger hammer?
Do you think I can use some focused heat, such as from a butane lighter or a torch to release the threadlocker, and dispense with removing the selector ring? Or is the risk too high of excess heat melting/cooking the ring? I was thinking of wrapping the exposed surface of the ring with metal foil, hoping that the minimal contact with the rest of the light would mean minimal heat transfer to the ring.
In any case, the light itself in stock form seems quite nice. The beam is a very nice white, and very smooth, though possibly a bit narrow. I measured about 8000 lux at 1 meter for the hot spot. Tail current draw on max was about 0.7A. On my bench supply, it looked like the driver pulled about 3.7W-3.8W when running in regulation. The minimum input voltage to reach regulation looked to be around 4.5V, which unfortunately means that 1x17670 (or 1x18650 if I bore the tube) isn't going be ideal. Since I can't open the head (yet), I couldn't measure Vf or If. A ceiling bounce comparison to a Seoul P4 U2-bin driven by an SOB1000 was very favorable. The U2-bin was only slightly brighter using my Mark I eyeball measurement.
Any ideas as to the max Vin that the driver can take? I would assume that 6.4V for at least brief periods is ok, since that would be the OCV for fresh 2x123As. But can it take 8.4V for brief periods, and 7.4V-8.0V for longer periods without frying?
TIA.
Edit: I got the selector ring off. The head is still uncracked. Probably needs more heat.
