Surefire X300
elipem01
Can the X300 accept AW RCR123s or is it primaries only? Also, have there been any rumors of new Surefire handgun lights coming out in the near future? Been looking to get one of these for a while but would hold off if something new was coming out soon. Thanks.
I would not use anything except primary lithium CR123a's in the light. The higher voltage from the RCR might blow the LED.
The newest X series light is the X400, which is a X300 with a red laser. It has a different mounting system(more permanent ish). Same brightness light output.
Usually when people say RCR123, I'm thinking typical 3.7v ones. But there are 3.0v (3.2 or something) ones. Which RCR123 are you using, elipem01?
Thanks for the input. The cells I have are the 3.7 volt. I'll probably just use primaries instead of trying to find the 3 volt rechargeables. A light like this won't see heavy use anyway.
I wouldn't take a chance on pushing it with something that needs to be relied on 100% like a weapon light. Stick with primaries in an X300.
Nice light by the way.
MSax
