Did you use Streamlight Scorpion bulb ?2023 up
How can he do that without a socket?Did you use Streamlight Scorpion bulb ?
Does it work instead of 4812 ?
I mentioned in post #2 "If you have the socket"fivemega not yet, still hunting for the socket, like chillinn said ;)
First they pick a battery chemistry they are going to use in flashlight then consider about brightness, run time, bulb life and flashlight size.I am having a heck of a time figuring out all the xenon Streamlights, what cells they used with what voltages.
A "little" late in the game since Tad closed his doors, but perhaps someone has a spare one...
PM please if you'd have one.
Thanks!
Example: If you are using two cells of primary CR123 and brightness of about 60~80 lumens, and run time of minimum an hour which shouldn't be more than 1.2A Amp, bulb life shouldn't be more than 40~50 hours and flashlight size can't be smaller than 4.5"
