Hi, I'm a new guy. :wave:
I didn't notice an introduction thread so I'm sorry if I may have overlooked it.
For a few years now I've been tinkering with hobby level electronics. Just recently I've taken a course involving advanced level electrics (chemical engineers don't really learn much about electricity). So I've picked up a good deal about resistance, calculating current load, differences between parallel and series, finding voltage drop in wire lengths, etc, but most importantly how to solder :candle:. I've used this to help me create custom wiring harnesses for aftermarket horns, fog lights, wire up foot well lights, make myself a custom glove box light, and so on. As the title suggests, I want to do something a little bigger; I want to create a series of perfboards and replace the horrible incandescent bulbs in my tail lights.
I've researched some background for my goal and found this forum along the way (I'm surprised at how helpful and not "assholish" the members here are, compared to some forums I visit[ed]). I found this site which converts MCD to Lumens: http://led.linear1.org/lumen.wiz. Which poses my first question:
Next is my inquiry about wiring the LEDs. First off:
Where the orange portions are copper substrate. So that I can simply solder the leds to the board and not screw around with needed to connect the leds by their feet. The board can either be like that with width-wise rows or height-wise rows. But honestly, just access to a board supplier would be good enough.
That said, I've been using this site to rough up an idea of how I could make my circuit: http://ledcalc.com/
Using the parameters 12v, 3.5v-drop, 100mA current, and 15 leds, you can see it says to do five parallel columns with 3 series-leds in each row. This is what I was planning on for my reverse and turns. However, for my brake/tail portion I want to do 10 columns by 4 rows.
If you don't want to read all of that, could some one atleast answer this for now:
- How do I compare LED brightness? I want to make a board of 15 leds in 3 rows for the reverse lights. The leds I'm looking at are 140° leds with a rating of either 110,000 mcd or 230,000 mcd. Would 110cd be more than enough?
- Equally so, I'm looking at the same type of led for the brake/tail portion and the turn signal portion. Would 110cd be overkill? Would 50cd be more then enough for brightness?
- Where can I get some circuit boards? Radioshack has some but I think they're trying to ripoff customers. And I've had horrible luck on eBay. I just don't know what to search.
- How can I accomplish this? Can I follow the same pattern but just add on 5 more columns and 1 more row?
- Is 110,000mcd x 15leds plenty bright for reverse lights? And is 230,000mcd overkill as far as brightness goes. How bright IS 230,000mcd?
