Test/review of Ampsplus 21700 5000mAh (Black) 2020
HKJ
Copenhagen, Denmark
[size=+3]Ampsplus 21700 5000mAh (Black) 2020[/size]
Official specifications:
  • Battery Size: 21.20mm x 74.40mm
  • Nominal Voltage: 3.60V
  • Nominal Capacity: 5000mAh
  • Rated Capacity: 4950mAh
  • Charging Method: CC/CV 4.20V
  • Discharge Voltage: 2.50V (Average Cut Off)
  • Operating Temperature: -20 ° to 60 °C
  • Standard Charging Current CC: 2450mA
  • Rapid Charging Current: up to 4900mA Max. ( Not for cycle life )
  • Continuous Discharge Current: 10A
  • Battery rate: 2C
  • Max. pulse discharge current: 14.7A
  • Measured Energy: 17.6Wh
  • Cycle Life: Capacity 3802mAh after 500 cycles (80% of the rated Discharge Capacity RT)
  • Weight: 72gr. max
  • Colour: Black, Silver, Purple
  • Protection Circuit Board / PCB: Yes, Protected
  • Version: Button Top
  • Type: Rechargeable, INR, High Drain
A protected high capacity 21700 LiIon cell.
The two cells match nicely, capacity drops when drawing higher current.
I forgot the temperature sensor on the A cell.
The protection circuit trips at a fairly high current, but it did break my 20A discharges.
[size=+3]Conclusion[/size]
It is a good protected cell for currents below 10A (Preferable a couple of amps below) with lots of capacity.
[size=+3]Notes and links[/size]
The batteries was supplied by Ampsplus for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
