kreisl
- Joined
- Jul 5, 2012
- Messages
- 2,244
yeah, green snb led would mean that the program finished normally. a program on a bad cell can finish very fast, see MH-C9000 behavior on bad cells . termination criteria like cut-off voltage or target voltage are reached fast due to the high internal resistance which causes a high voltage step at high charge (or discharge) rates. so that's explained by that.
the connection break is not easily explained by me, the maker would know the internals (code) and the explanation. but it is something like what i said. when the onload voltage surpasses an internal threshold, the slot breaks the connection (for 'safety reasons') and throws a Break Connection message.
If you try to charge with a low current, you'll see that there will be no Break Connection message.
