Test/review of E-Stream ES18650-26EP 2600mAh (Pink) 2021
HKJ
Copenhagen, Denmark
[size=+3]E-Stream ES18650-26EP 2600mAh (Pink) 2021[/size]
Official specifications:
  • Nominal voltage: 3.65V
  • Energy: 9.49 Wh
  • Discharge cut-off voltage: 2.75V
  • Maximum charge voltage: 4.2V
  • Internal Impedance ACIR: 25mOhm
  • Standard charge current: 1.3 (0.5C)
  • Standard charge cut-off current: 130mA (0.05C)
  • Maximum continuous charge current: 2.6A (1C)
  • Maximum pulse charge (< 2s) current: 5.2A (2C)
  • Standard discharge current: 2.6A (1C)
  • Maximum continuous discharge current: 15A (5.7C)
  • Maximum pulse (< 1s) discharge current: 20A (7.7C)
  • Cut-off temperature limit discharge: 60°C
  • Cycle life (80% of initial capacity): 1000 cycles (standard charge/discharge)
This is a 18650 cell with moderate capacity and moderate current capabilities.
The two cells tracks nicely and can easily deliver the rated 15A. My 30A test looks a bit strange and one of the cells got damaged during it.
[size=+3]Conclusion[/size]
The cells looks fine, they are not high capacity or high current, but they have a rather high cycle count (can handle many charges/discharges).
[size=+3]Notes and links[/size]
The batteries was supplied by E-Stream for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
