HKJ
[size=+3]Keeppower 14500 950mAh P1495U (Blue-white) 2020[/size]
Official specifications:
Protected 14500 with USB charging and not over sized.
The box contains two batteries, USB charge cable, instruction/date sheet and a plastic box for the batteries.
The supplied USB cable can charge two batteries at a time, but any micro USB cable can be used to charge a battery.
The two cells tracks fairly well and the over current protection prevents too high current.
The batteries can be charged on a regular LiIon charger.
But also with a USB charger.
[size=+3]Conclusion[/size]
These batteries are definitely not for high current, but works nicely at lower currents. The USB charging makes it easy to charge them mostly anywhere.
[size=+3]Notes and links[/size]
The batteries was supplied by Keeppower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
![DSC_4074.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4074.jpg&hash=ddf97044048cb7466b9a2d52c0afd62c)
- Voltage: 3.60V
- Rated capacity: 950mAh
- Minimum Capacity: 900mAh
- Discharge cut-off voltage: 2.50V
- Charge voltage: USB 5V +/- 0.5V
- Standard charge current: 330mA
- Maximum constant discharge current: 2A
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-info.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-info.png&hash=3af4458a1a963c3d3de0f8c9d8a58e50)
![DSC_4072.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4072.jpg&hash=8060c2052bd1073050ea113af764a97a)
![DSC_4073.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4073.jpg&hash=e2ffa42ec3e648abd4241fcd2b135ccd)
![DSC_4075.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4075.jpg&hash=418566688b30f34539a1f90018d3b4a0)
![DSC_4076.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4076.jpg&hash=eae2c8473afc556f1b284a93fc82f5b7)
![DSC_4077.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4077.jpg&hash=e080aaaf0ae27092c4ef9d45d554b3bc)
![DSC_4078.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4078.jpg&hash=4f8209eb02afc42d9f78dec72e1325e2)
![DSC_4079.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4079.jpg&hash=f213c028d5e8e224d2b89a0dfbbf24ac)
![DSC_4080.jpg](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FDSC_4080.jpg&hash=91a2475d0351a49628ef7c96270ee4e0)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-Capacity.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-Capacity.png&hash=2012d323b41b63038a7ea23bdf763926)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-Temp-2.0.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-Temp-2.0.png&hash=22ff0de9e3ee67218e8b11e884004275)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-CapacityTimeHours.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-CapacityTimeHours.png&hash=dcf89ae8d49ee66b67c7b073fe22a103)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-CapacityTime.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-CapacityTime.png&hash=26c6abe45870f4ab189a9655f4e390fc)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-Energy.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-Energy.png&hash=ebbbe4219f59de530e4696caf07f2e90)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-PowerLoadTime.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-PowerLoadTime.png&hash=fbfab8f6fa51c85101c5ab80440855ac)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-TripCurrent.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-TripCurrent.png&hash=2bb62f41e91232ef1bff8cd4d73b14c4)
![Load%20Sweep%2020201203170939.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%2528Blue-white%2529%25202020%2FLoad%2520Sweep%252020201203170939.png&hash=a83f1bf62b23323bee59b9f236d68966)
![Keeppower%2014500%20950mAh%20P1495U%20(Blue-white)%202020-Charge.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%28Blue-white%29%25202020-Charge.png&hash=524612b3bcc03484170789b3454f76c7)
![USB%20Charge%20Test%2020201123205238.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%2528Blue-white%2529%25202020%2FUSB%2520Charge%2520Test%252020201123205238.png&hash=d12a29b832c453f8a02e4447a6603a7b)
![Discharge-Keeppower%2014500%20950mAh%20P1495U%20%28Blue-white%29%202020-pulse-0.5%2010%2010-IR.png](/proxy.php?image=http%3A%2F%2Flygte-info.dk%2Fpic%2FBatteries2012Small%2FKeeppower%252014500%2520950mAh%2520P1495U%2520%2528Blue-white%2529%25202020%2FDischarge-Keeppower%252014500%2520950mAh%2520P1495U%2520%2528Blue-white%2529%25202020-pulse-0.5%252010%252010-IR.png&hash=8b065bfbe5ff5a72487a4d170a9a731e)
