Test/review of Keeppower 16340 850mAh P1634C2 (Black) 2020
HKJ
Copenhagen, Denmark
[size=+3]Keeppower 16340 850mAh P1634C2 (Black) 2020[/size]
Official specifications:
  • Voltage: 3.70V
  • Rated capacity: 850mAh
  • Minimum Capacity: 800mAh
  • Discharge cut-off voltage: 2.50V
  • Charge voltage: 4.20V +/- 0.05V
  • Standard charge current: 500mA
  • Maximum constant discharge current: 3A
Protected LiIon 16340 batteries from Keeppower.
The two cells do not match perfectly, but being a protected cell it do not prevent using them in series.
Discharge-Keeppower%2016340%20850mAh%20P1634C2%20%28Black%29%202020-pulse-0.5%2010%2010-IR.png
[size=+3]Conclusion[/size]
The battery has good capacity for its size and protected makes it safe to use in series configurations, but as usually for protected cells it is a bit longer than a standard cell.
[size=+3]Notes and links[/size]
The batteries was supplied by Keeppower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
