Test/review of Test of Vapcell INR14650 1100mAh V11 (Gold) 2020
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR14650 1100mAh V11 (Gold) 2020[/size]
Official specifications:
  • Model: INR14650
  • Size: 14.0*66.7mm
  • Type: Button top
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.75V
  • Typical Capacity: 1100mAh (0.2C discharge)
  • Min capacity: 1050mAh (0.2C discharge)
  • Weight: Max:28g
  • Internal resistance: Max:18mOhm (AC 1kHz)
  • Standard Charge: 500mA,CCCV 50mA cut-off
  • Quick Charge Current: 1500mA
  • Max Continuous Discharge Current: 6A
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~75°C
  • Storage Temperature: -5°C~35°C
A 14650 LiIon battery, this is AA cell in diameter, but as long as a 18650 cell.
The two batteries matches well and keep the capacity first starts dropping above 3A.
Discharge-Vapcell%20INR14650%201100mAh%20V11%20%28Gold%29%202020-pulse-0.5%2010%2010-IR.png
[size=+3]Conclusion[/size]
It is a unusual size, the extra size gives it a slightly more capacity than 14500 cells.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
