HKJ
[SIZE=+3]Vapcell INR18650 3000mAh S30 (Red) 2020[/SIZE]
Official specifications:
This is a fairly high current 18650 cell from Vapcell with good capacity.
The two cells tracks nicely and hold voltage fairly well.
[SIZE=+3]Conclusion[/SIZE]
This is a fairly good cell with both capacity and high current.
[SIZE=+3]Notes and links[/SIZE]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Nominal Capacity: 3000mAh
- Min Capacity: 2900mAH
- Nominal Voltage: 3.6V
- Discharge End Voltage: 2.5V
- Standard Charging Current: 2A
- Charging Voltage: 4.20 +/-0.05V
- Max. Continuous Discharging Current (Vapcell specification): 25A
- Dimensions: 65.00mm (L) x 18.3 mm (D)
- Weight: 50.0g max
