HKJ
[size=+3]Vapcell INR26350 2000mAh A20 (Red) 2020[/size]
Official specifications:
A 26350 sized LiIon battery, this is a uncommon size.
The two cells match nicely and can deliver the rated 6A, but not much more.
[size=+3]Conclusion[/size]
The batteries works fine, they are neither high current nor high capacity, but the size is not very common.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Battery size: 26350
- Battery chemistry: Li-ion
- Voltage: 3.7V
- Minimum capacity: 2000mAh
- Maximum discharge current: 6A
- Height: 35.00mm
- Diameter: 26.10mm
