So now I am looking for another Incan and probably will build a modded M@g or something. But does an unregulated incan loose brightness very quickly, and does the AW soft start setup provide regulation like the A2? Do other manufacturers make regulated incans?
Brightness will essentially follow the discharge curve of the cells you are using. If you run high quality LiIon or NiMH cells, output will drop somewhat in the first couple minutes, but then stay constant after that for almost the entire runtime, until they need to be changed.
AW's multilevel soft starter does not provide regulation. It's a soft starter that also has a lot of low-resistance mods included in it -- including replaced switch, and bulb-socket. It's also smaller so it makes more room in the battery compartment for longer cells like the AW C Cells. AW will soon be coming out with a regulated hotdriver for the D-Maglites, but it won't be multilevel.
The advantage of regulation has more to do with the fact that you can run your incan right up to the limit of what the bulb can tolerate, so color temp is higher (whiter). Even simple softstart will help in this respect. With DD you have to plan some "headroom" so the bulb can survive the first minute or two on freshly charged cells without flashing. With regulation you're also free to use different battery combinations, and not bound to a particular voltage.
If you were to go for a modded mag, I'd pick one of the following configurations:
1) 2C 5761 -- 2xAW C Cells. AW Hotdriver (recommended). Runtime: 25/50/100 minutes
2) 2D 5761 -- 2xKaidomain D Cells. AW Hotdriver (required). Runtime: 45/90/180 minutes
3) 3C 1185 -- 3xAW C Cells. AW Hotdriver (recommended). Runtime: 1/2/4 hr
You can see comparisons of these to each other in the link in my signature (though not all of mine are using the AW switches).
Reflector Options:
SMO -- maximum throw.
VLOP -- nice tradeoff between smooth beam and throw
MOP -- nice beam pattern
reflector can be bought from Kaidomain ($15) or Fivemega on the forums ($30, but higher quality). The Cells and driver can be bought from AW on CPF. Bulbs are available from Bulbconnection.com. AR coated glass can be purhcased from flashlightlens.com or kaidomain.com
Expect over 1000 lumens out the front from any of the bulbs I suggested, and total price tag between $150-200 everything included (bulbs, host, batteries, etc). These are expensive but worth it IMO. Think about how nice your A2 is at 50 lumens. Now multiply that by 20
