The Bazooka
Otokoyama
So Cal
I've had this guy on the drawing board for months. I've been interested in making a 4AA 5W HD (BB750) light, since I believe this offers a good combination of brightness and runtime. However, my reflectored 5W HD lights have had beams that simply aren't tight enough. The solution: a Carley 3" parabolic. The geometry permits better collimation with the larger 5W source, plus captures more light that would otherwise be spilled.
I call this short, stubby, yet reasonably powerful light The Bazooka.
One of the interesting features is the switch. About 95% of the time I "strobe" lights, using the switch in momentary mode. The Bazooka's switch mechanism, extracted from a tapeswitch, is within the black ring. Pressing anywhere on the ring activates the switch. The advantage of this switch is that it doesn't add to the length of the light since it encircles the emitter / heatsink / electronic assembly. I'll figure out the disadvantages through use.
Here's a size comparison with a TigerLight on the left and a E1e/KL1 on the right.
I won't provide beamshots since the current reflector is the stock polished aluminum, and I suspect the metalized reflector (preferably orange peel) is perhaps 30% more efficient. The hotspot is about 1 foot in diameter at 15 feet.
very cute /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
and a very interesting switch! any constant on?
bernhard
wow, amazing!
i had no idea that this "tapeswitch" stuff existed, but i have given serious consideration to similar means of activation. i was actually thinking of using dozens of small switches around the outside of the light /ubbthreads/images/graemlins/crazy.gif /ubbthreads/images/graemlins/icon15.gif
talk about small /ubbthreads/images/graemlins/drool.gif
Congrats on the Bazooka
Really nice light! What is the pricing on the tape switches like? Did you modify the tape switch or did you use it stock? Hard to intstall?
WOW! /ubbthreads/images/graemlins/ooo.gif I love it! /ubbthreads/images/graemlins/buttrock.gif
Great name too. Very clever idea with the tapeswitch.
BC
There is no constant on.
The problem with the tape switches is getting them to bend around the circumference without switching them on. I finally resorted to taking apart the tapeswitch and using the internal mechanism in an odd way. Tapeswitches run about $25 each. /ubbthreads/images/graemlins/frown.gif
Very nice and clean! I like the ergonomic switch solution!
Don
We have some truly gifted craftsmen on this BB. How do you manage to hold such a slippery-looking thing?
OOH! Very nice work as usual Paul. It appears that the large reflectors are becoming your particular niche specialty, well done!
I do know that short lengths of the tapeswitch can be had on those little pressure switches wired to a threaded cap for replacement of the MiniMag's, would just a small piece installed at one point still work?
I think they can be had for like $3.95 at Cheaper Than Dirt...
Very nice work! Can't wait to see some beamshots of that one. Really like the switch solution as well.
Great! /ubbthreads/images/graemlins/thumbsup.gif
I'm very interested in the switch and the reflector. /ubbthreads/images/graemlins/grin.gif
I should mention that the reason I went with AAs is that they're NiMH. It's also designed to take a screw-in 2" parabolic, but the beam with the 3" is just what I was looking for.
This is what's inside. The thick orange lines are wires in drilled channels. "Battery" is a 4AA battery holder with terminals at the top which mate with delrin-insulated terminals within the heatsink which is reasonably big plus transfers heat to the reflector.
Oh, man... I got a D in mechanical drawing /ubbthreads/images/graemlins/icon15.gif
You fellahs amaze me. Terrific rendering, Oto. /ubbthreads/images/graemlins/thumbsup.gif
BC
Although I couldn't be able to see any picture, combination of great reflector, 4AA and 5W already good enough for me to get one at least:-)
Alan
