CodeOfLight
I finally finished my coolest light EVER!!!!
I took 7 cree LEDs, 3 of which are NOT on a MCPCB, four of which are, and mounted them to a disc of 1/8 " aluminum (Because I had so much trouble soldering to the ones that were not on a MCPCB, I switched to pre-mounted ones.)
On the back of the disk (where you can't see) I built a little tunnel of copper RAM heatsinks.
Inside the tunnel, I potted a shark driver board turned up to maximum. This drives the LEDs at 310ma. I could have driven 6 at 700ma, but the entire setup gets way too hot. If I change my mind, all I have to do is short one of the LEDs.
The blue things on the face are another set of RAM heatsinks, doubled up two high and Arctic Silvered in place, with small aluminum spacers underneath where they needed to sit up off of the board. Some of the more "sticky outey" fins are cut off because they were causing a shadow in the beam.
It's Total light output is all flood with absolutely NO artifacts., and I estimate at around 490 lumens. It completely BLOWS AWAY the other Ryobi incandescent light I have. It will run for 2.5 hours straight before suddenly dimming by about 50% as the shark drops out of regulation, slowly dimming from there onward.
This thing is MUCH brighter than a coleman lantern, will easily mount to a tree with the light rotated up and illuminate an entire campsite. It will also illuminate a large tent with enough light for everybody in the tent to comfortably read, while pointed at the side wall of the tent.
I call it the "Lamprey" (emphasis on LAMP) because of the obvious resemblance.
Pics:
http://img1.imagefuse.com/upload/codeoflight/IMGP2175.JPG
http://img1.imagefuse.com/upload/codeoflight/IMGP2176.JPG
A real Lamprey:
http://img1.imagefuse.com/upload/codeoflight/lamprey.jpg
Pics:
A real Lamprey:
