rizky_p
I opened up my KD Q5 drop-in. Let the pictures tells the story.
The back of the Dropin where the driver used to be. The red and yellow heatshrink are there to add the length to the original cable which is a small black and yellow cables. The original cable is too short so i add more length to be usable for external driver.
The two part driver.
The front side of the driver. The + and - to the LED are clearly indicated and where the cable to the LED used to be.
The back side of the driver where alot of thermal compound is applied. probably the buck side?
the second part of the driver doesnt have any componen on it, it just a pass through board.
Notice the small pedestal where the Q5 sits? it is small and alot of thermal compound there but the LED is not glued, it is being held by the friction.
Other angle shows how the cables and led base are soldered.
Hope you guys enjoys it. thanks for looking.
Regards
Rizki P
Regards
Rizki P
