Re: The SF M6-R: a regulated rechargeable SF M6 (H
[ QUOTE ]
bwaites said:
js,
What are the dimensions on the pack and regulator combo?
Might this be used in another body with another bulb?
Bill
[/ QUOTE ]
Bill, what did you have in mind? I would suggest that if you can avoid it, do NOT integrate the battery pack with the regulator. It's an extra level of hastle. Anyway, as for the dimensions, they are something like a little less than 3.6" long and 1.44" in diameter (for the circle which encompases the rounded triangular shape of the pack). Plus, the output is set to 6.8 volts and cannot be changed, so that limits things a bit. Of course, you can order an LVR set to whatever voltage you want (within reason).
Larry, I'm honored by your interest. BN's review was an eye-catcher, wasn't it.
Topper, you're not too late. You're early. I will be opening a B/S/T signup thread sometime in Jan or Feb of 2005. Worst case, cost will be $110 for the pack and $75 for the charger (or $10 for the cable only if you already have a stand alone charger).
