I confess that I am most interested in your last sentence - since you are stating that the lens on the SF P2X-B scratches up too easily, that means that you have experienced this with the light, am I correct? :ironic:
BTW I've been using an older lexan-lens SF C2 modestly over the past ~18 months and it doesn't have a single scratch on it yet. :shrug:
Since I own it & use it, I do feel as though I can comment on it to a certain degree.
Edit: Not trying to go OT, just commenting on the comparable Lexan lens in my old C2.
Ive owned the new Surefire Z2X CombatLight and after just 4 weeks of normal use I noticed a couple of small scratches on the lens I then wiped the lens with a clean soft cloth and after I wiped it the lens got scratched up even more just from a soft cloth.
The SF P2X-B is using the same plastic lens as the Z2X uses,.... so I have experienced this lens.
1. Plastic lens.
2. I personally don't care for lights (or drop-in modules, for that matter!) that require button-presses to change modes.
3. No Lego ability.
I just picked mine up this morning from a Surefire dealer and have been playing with it all day.
First impressions are great, its 5.4" and doesn't have a problem with bump changing. The light itself is sturdy feeling, with nothing rattling about.
The reflector is a light orange peel and it gets warm rather quickly.
At 5' on High (500 lumens) I get a nice 1.5' bright spot and a spread of about 10'
This light floods a room or a field nicely. I have not gone out and played with its throw to much, but it can hit trees about 200 yards off noticeably at dusk
Although the head/lens does look like it can be unscrewed it is glued on.
Ill post some beam shots tomorrow when I have had some more time to play with the light.
See post #40; or #15 and follow the link.
