Tachead
Ok, not tried it with any other cool white, but I will have a go.
I know my HDS has low CRI, and the colours (albeit only greens and browns when I tested it at a golf course last night) from the EagleTac were very similar to the HDS. That's why I assumed it also has low CRI?
Before last night, I have tried it on my kids toys (that have a lot of colours) and the reds certainly do seem vibrant with the EagleTac.
Why did the colours of this Eagletac seems awfully similar to that of the low CRI HDS, when tested out on the green (and browns)?
Its hard to say for sure without testing both and comparing the spectral graph but, it could be that the HDS has similar green and brown values. Remember that CRI is only a small part of the picture and only takes the average of 8 colour samples into account. It is actually one of the least accurate systems to measure a light sources colour rendering(especially LED). You can have two emitters with the same CRI value but, one can be better in certain spectrums then the other because it is an average. Also, you may just prefer the way a certain emitter renders a certain colour. That does not however mean the one you prefer is the more accurate rendering and closer to the way it will look in sunlight. Colour temperature can have an effect on the way colours look too as tint will change along the black body radiation line(yellow/orange towards the warm side and blue/purple towards the cold). Then there is the tint difference when the a light sources falls above or below the black body radiation line.
This is a complicated subject.
