Hello,Newbie here as a newbie to a used Thor X 10,000,000 light I bought used, I am charging now, The battery shows just over 15 volts while charging, When I got home with the light it did not work, seller said the battery does not hold a charge, I have the charger on now, Will see what happens,
My question is if it does not hold a charge should I buy a new battery and roll with it OR would it be better to Mod the light to make it BETTER??
I need a good bright light to see things at night.
Thanks for your help.
Brian
Brian
