Ti threads need a while to wear in, I guess they always feel a litle bit grindy. I don't understand where the problem with a Clicky is, you tighten the light and don't have to turn the head again until the battery has to be changed! :shrug:
Nevertheless, there are better solutions than Nyogel, nfetterly sells the exact lube that is used by McGizmo. I don't have it, but may get it, as I'm gonna have some twisty titatium lights soon. Then there was a guy who spoke about baking soda. You have to use the search function for the exact quantities, but you take your favorite lube, nyogel in your case and add some baking powder. I didn't try that...
Another idea is to break the threads in. Just inform yourself how you should proceed to have the best results and than you can start twisting, again and again and again! :eek:
