MWClint
Just finished this mod. It's tricky because theres not much room to work.
it uses the original sapphire light engine.
neutral white xpe on left, high cri seoul sapphire on right. :)
Had to coat the outter edges of the xpe so it doesnt short out on the head.
xpe on left, high cri seoul on right
i was surprised, the neutral xpe is really bright and has a wider beam than the seoul. the seoul has got a noticable ammount of red in it.
used by themselves, however they both look white.
xpe vs an old nichia 5mm :laughing: :laughing: :laughing: :grin2: :popcorn:
seoul on bottom xpe on top. at least twice as many lumens. :devil:
side shot of finished pill.
another shot
beamshot on its own. nice tint.
another shot
inside the head..heatsink sits flush against the inner lip.
I could easily design a large heatsink in there for pushing 200-350mah
to the led. plenty of space inside the sapphire. I have some driver ideas
that fit.
flattened the 5mm led and drilled hole thru center
just some in progress work.
more in progress..
workspace.
guaging the height
hole thru led. the nichia makes for a solid base,
and it seems as if the plastic 5mm's do transmit heat..fingers got hot while
drilling thru the 5mm core. haha
another shot
another shot
that fit.
more in progress..
workspace.
guaging the height
