They throw about the same - very well indeed.
The Malkoff is focussable and has longer run times.
The Tiablo is much lighter - and is small enough to slip into your pocket.
Specifications:
Cree 7090 XR-E LED Q5 WC bin - as good as it gets!
Step down constant current driver, High efficiency with dual mode DC-DC regulator (PWM / PFM), working voltage is 2.7V to 10V. Replace battery when the light is too dim.
Two stage output. High output: 1A at maximum 256 Lumens for about 3.5 hours Low output: 300mA at 60 Lumens for 8 hours (runtimes based on Li-Ion 18650 battery)
42 mm diameter x 33 mm deep reflector provides greater efficient illumination over longer distances.
Supports three sizes battery, one 18650 Li-ion battery, two pcs CR123A or RCR123A battery.
Type-III hard anodize. Aircraft aluminum T7075.
Water proof to 5m/15ft.
Toughened ultra clear glass lens with AR coating.
Tactical clicky switch: Low-High-Off.
Length 158mm, Head diameter: 45mm, Weight: 155g(battery excluded)
Will stand in candle-mode.
Anti-roll ring makes it safer to put on desk or table.
6.2 inch long, Aircraft aluminum (T7075) :twothumbs
