Lots of times lights ship with silica already inserted in the battery tube.I just put silica gel bag in chamber and close tail cap. You must use dry silica gel. I put my small "do not eat"(comes ith electronic devices) bags to 120C (about 240F) owen for 1 h to make sure that these are dry.
Most electronics and many other products include the sachets of 'Do not Eat - Silica gel' which is exactly what you need.
Read the whole of this thread for some more info.
Make sure you don't insert damp batteries (due to sweaty hands) to prevent recurrence.
There shouldn't be any condensation in this light. It's unacceptable and is most certainly not normal. You should be able to use this light on any setting for any amount of time til the batteries are dead.
I agree 100%! This is why i have not yet baught any TK75 since Fenix has not yet given any respond about what causes this issue and how they will solve it. Yet i don´t know if the condensation issue is only on the old version or if it has been issues of it on the upgraded TK75 as well.
On a light with a retailprice of 200US$ one could expect that issues such as condense under the lens should not appear.
I have my eyes on a dealer at Ebay who sells the TK75-L2(the upgraded one) with 4x18650 batteries and a charger to a good price and i am considering it,but i will wait with my purchase untill i know more about this condensation issue and if it has been an issue of it on the upgraded TK75 as well.
One thing for sure is that if i received a TK75 that has the condensation issue,i would not put it the freezer or putting in silica gel in it-i would return it to the dealer immediately! It´s not the customer who should have to deal with any issues like this with their lights. It falls under the warranty which one has paid for in the first place.
It APPEARS that I have eradicated the "Condensation Issues" with the help and suggestions of "LFP11"!!
I heard of silica gel and it's way of drawing out moisture. But it took LPF11'S suggestion for me to try it. Mostly because it worked and he has a TK-75 that he used it on.
-Silica gel in oven at 275 F. for One hour to make sure all moisture is out.
-Put one packet in Battery tube for 3 days
-Ran light for 62 consecutive minutes on TURBO-NO CONDENSATION FORMED!!
Repeated same process. Tonight I got the SAME RESULTS! 62 minutes of Turbo-NO CONDENSATION UNDER LENS!
:twothumbs
Head must not be hermetically sealed as LFP11 indicates above!
THANKS LFP11!! :thanks::thumbsup:
Yeah, but it seems that this light puts some spell on owners, and they refuse to return it for a refund. I've never used one, but it must be a hell of a good light for people to put up with this fogging issue, and the potential for longer-term problems from moisture being forced inside the head.
I'm not sure whether Fenix deserves a thumbs-up or thumbs-down.
ATTENTION:BLERKOID! I FORGOT TO QUOTE YOU. THIS IS FOR YOU!
The light does not need to be in a sealed bag. Just put a packet of silica gel in the BATTERY TUBE with end cap on securely.
I bought Ten[10] 3 gram packets for only $5.00 on Ebay. I put in oven at 275F. for 1 hour,then they were absolutely dried out. I just used one packet in the battery chamber
Make sure you take out the battery carrier and batteries!
After I did this for 3 days and got success, then I kept the silica gel in Batt. tube for 2 days,success again. Now,I can use it every night if I want and when not in use[just to make sure] I keep the silica packet in the EMPTY battery tube.
This is just me. after each use of silica packet I put them in a separate[ marked used] baggy. when I get 8 or 9 I put back in the oven and start the process all over again.
good luck,it is a great torch!:thumbsup:
Thanks very much Capolini! This is very helpful! I am trying the silica trick tonight. I will have to buy more for a more constant solution. How did you know that you could put your silica gel packets in the oven?
Thanks again man! This is a huge help
The packets that I first tried to cook shriveled up :shrug: I must have had the wrong type, I guess. I just took them out of the packaging and cooked them and wrapped them in a coffee filter.
I have my eyes on a dealer at Ebay who sells the TK75-L2(the upgraded one) with 4x18650 batteries and a charger to a good price and i am considering it,but i will wait with my purchase untill i know more about this condensation issue and if it has been an issue of it on the upgraded ...
Absolutely! I'd send it back right away. I hear the new ones do it as we'll so I'd hold off.
Bottom line, should I get one???
Does the moisture affect the dang thing? Does it operate just fine with moisture there? Does it affect the beam throw and the flood??? MOSTLY WORRIED ITS NOT WATERPROOF. I mean it DOES rain....I COULD drop it in a river bed....
I don't care what anyone says (if anyone said it ) if moisture comes out....then it has to get in also....which means there is no way its waterproof!!!!
