TR-001 trickle charging question
pae77
Honolulu, HI
The LED's on my particular TR-001 reliably turn green when the batteries (14500's in this case) measure 4.16 volts on my cheap DMM (which I think reads about .01 volts low). If I then leave the batteries on the charger for an additional ~30 minutes, the batteries are brought up to 4.18 volts on my DMM. My question is: Is this additional ~30 minutes of charging after the LED's turn green OK or is it bad for my batteries?
I am confused because from what I have read, I gather that, in general, trickle charging Li-Ion rechargeables is bad, (causing plating, etc.). So is this ~30 minutes of trickle charging up to ~4.18-4.19 volts right after the LED's turn green on the TR-001 a proper part of the CC/CV charge process that is perfectly OK for the batteries on a regular basis, or is it the "bad" kind of trickle charging that may have negative effects on the batteries over the long term?
What you describe seems fine. The "bad" trickle charging is charging that goes on for 24 hours a day. Normal charging of a lithium ion cell should cease within about 3 hours or so. Within that time a small trickle charge at the end to bring the voltage up to 4.20 V is quite acceptable.
I wouldn't leave the batteries on the charger after they are up to the right voltage though. It sounds like that charger may not have a positive charge cut-off.
Yes, I don't know for sure whether it does or doesn't cut off completely at some point, but I'm assuming it doesn't unless/until proven otherwise. So I'll just leave them on for 30 minutes to an hour tops after the LED's have turned green. I don't want to charge my batteries above ~4.18 anyway, so this charger is working out very nicely for me.
If I need to use a charger that has a positive cut off, I have one of the Shekor's for that, but mine cuts off a little on the low side at 4.08/4.11. Do you think it is OK to start the charge on the Shekor and then top off to 4.18 on the TR-001, or is it better to just do the whole charge on the TR-001?
