Tri XP-G R5 Mag 1C
tx101
London UK
My 2 year old son decided to have an early night so that gave me a
chance to finally finish this little project :D
Host by Fivemega
Bezel, one of member Cfromc's Mako bezels
Download heatsink
3 x Cree XP-G R5s (not a hint of green :party: )
3 x Ledil LXP RS optics
Tri-flupic driver
Wow that is a sweet setup! What kind of battery are you using? I have to say it: Let's see some beamshots! :)
Yeah, that's a good looking light.
If you get a chance, please do post up some beamshots from outdoors. I'm doing a light simliar to this, but with a lot more emitters, and wouldn't mind seeing the hotspot/spill of this optic outdoors.
Thanks!
Hi, can you explain me, what battery config u used, because i'm trying to mod my magcharger with the same setup, but i'm currently searching for a suitable driver (boost 6Vin to 10Vout + 1-1.2A regulation). It's really hard to find a PIC to build a circuit around it....:S
I am using a single DX 25500 li-ion, I believe it is the same size as
the old AW C cell.
I will try to get some beamshots up tomorrow
Very nice Wai! I'm sure it's bright. :twothumbs
Looking forward to the beamshots. :)
Where did you get the Ledil optics? :thinking:
I was wondering what you were going to build next?
Very nice build.
I'd like to know what you think of the XP-G and optics combo, and how it compares to say an Tri XRE set up?
What level of current are you feeding the LED's?
If it ever stops rainning cats and dogs, beamshots !
a question more, can you see if 4 optics can be fitted?Thanks!
The optic has a diameter of 21.6mm, I am not sure if four will fit :eek:
led-tech.de 2.49 Euros plus shipping :thumbsup:
Something weird happened when I tried to take some measurements from
the tailcap :confused: Everytime I powered on, the light would just strobe but I did
manage to take a single measurement which I think was on "burst" mode
2.6 amps :devil:
Hmmm .... I dont have a tri XRE to compare, but when I compare it with
my quad R2 (Maxflex set at 700mA) it is noticeably brighter :D
The "money" shot :naughty:
about 20 meters
about 30 meters
Disclaimer ..... I admit, an Orang-utan swinging through the trees and eating a banana at the sametime can
take better beamshots than me :eek: :eek: :eek:
Just did some quick research on whether 4 LXP optics will fit in a Mag head.
Using the formula posted by member Al Combs here
unfortunately 4 LXP optics will not fit
We know that a Mag head has an internal diameter of 49mm and the optic
has a diameter of 21.6mm, therefore
21.6 x 2.4142135624 = 52.1470129mm
So we would need a circle with a diameter of 52.1470129mm for 4 LXP
optics to fit into :(
tx, I have seen alot of your flashlights and they are really nice. I have also seen alot of your beamshots.....what do you normally use to hold the camera? A paint mixer or a washing machine on a spin cycle. :poke: JK great mod.
Great outdoor beamshots! Thanks! lovecpf
4 of those optics will not drop in a *stock* Mag head, but with some filing on the optics, and a little boring of the head, they'll go in.
I got to see this little red monster at the London UK meeting at the weekend.
Fantastic output, really clean build, and above all it looks great.
The size of the 1C host is perfect. The polished metal front and back made a good contrast with the bright Red body.
Cheers TX101 for letting me play.
Is your tint pure white?? What binning did you chose? 1A0, 1B0, or 1C0??
I am building a XPG light but I'm unsure of the binning. I want cool white.
Thanks
