joniverson
- Joined
- Jul 21, 2007
- Messages
- 31
Hi,
Recently purchased a silver GLP-105? from Vital Spirit Ebay source with intent to increase power by the pot mod. I removed the oval button, but with this laser I was unable to gain access to the pot. I could see it, but it was quite angled away from the oval aperture. I then decided to pry the laser open to gain better access. I read the various tips here in the forum and other sources suggesting to use a knife or similar to work the top out of the cylindrical body, but this was no easy task! After marring and nicking up the top, I was finally able to separate the laser module from the body. The pot on this laser just didn't have a flathead like most normal pots and I had to adjust the far edge. I adjusted it until the laser got brighter and then quickly went out, then backed off to the point just before the laser extinguished. However, when I press the button, the beam is bright and then gets dimmer after a few seconds. I've had this happen on two lasers I've tried to pot mod. Any ideas why the power is dropping and is there a fix?
All in all, I'd say this particular silver GLP is different than earlier ones from the same source, and it appears to be harder to modify. Of course, I'm taking a guess here, but the instructions I've read concerning mods are not as easily performed on this laser.
Appreciate, in advance, any advice or tips.
Thanks,
Jon
Thanks,
Jon
