Morepower!
do you think the bulbs would really go or just stop working?
i cant use fat boys on my vt, as there too long. the cheap h7 bulbs are already very close to the ballast. But ive stocked up on 4300K bulbs.
EDIT:morepower, when you posted...
what was the total lux? And does anyone think they can work the estimated bulb lumens of 60w output overdriven?
thanks. :thumbsup:
You are really testing my memory here Flash, which is not good at the best of times. What I do remember is the Lux readings were taken at a distance of ~150mm from the bare bulb and the readings were in the 200,000 range. As far as the cheap bulbs blowing up, from what I've read the more you overdrive a bulb the higher the pressure is in the arc chamber. And I do remember someone saying they had one blow up on them. Hopefully someone more knowledgable will chime in and give some more info on this. I just know I'm not prepared to take the risk, and I think someone said you get more Lumens from the Fatboy ???
