PCC
I use my Mini MagLite, with the Nite-Ize 3-LED module, as my AA battery vampire. I usually rotate my cells through three different lights that have lower and lower minimum voltage requirements where they eventually end up in this particular MM. Yes, it's my sacrificial lamb, so to speak.
I bring three 2AA flashlights into the bathroom with me every evening to cut energy costs while I'm in the shower. I use three because the cells are, generally, running low on power and I need three to get enough light to see what I need to see to get the job done. Three nights ago, while towelling off, I heard a pop, like a marble hitting a window. I didn't see anything out of the ordinary so I dismissed it. After dressing I reached for the MM that was tailstanding on the glass shelf when it turned off from the movement. I then tried to turn it on and off again but it did not turn on. I pulled the batteries and found that the cell closer to the head of the light had dumped acid. Wow, close call. I quickly dismantled the light and flushed the acid out of the tube as well as disposing of the cells.
The next night, after rotating the cells, I had a very similar experience, though this time I heard a tapping sound coming from the light like water dripping from the faucet. Opening the light I found that the rear cell had leaked into the Nite-Ize tailcap switch and the switch was crackling! I flushed the tailcap out with tap water but it kept crackling for about 20 minutes more.
I'm eventually going to buy NiMH batteries for everything in the house that uses AA batteries, but, until that happens, this little Mini MagLite is just going to be my sacrificial lamb. The Nite-Ize 3-LED drop-in is a great battery vampire but it will keep trying to light up even on a single depleted cell. I've run it with as little as 0.7VDC, though at that point it is running in moonlight mode.
